Yes it is true. Tungsten carbide bonds via brazing by the same mechanism as steel or any other metal. The layer at the junction is basically a mix of the two - the braze or solder alloy and the base metal.
I don't think this is fair -- but, well, it depends.
Cemented carbide (the most common kind) is WC in a Co matrix. Co has a little solubility for C and W but not very much even at the melting point. You'd have to go very high indeed to get a full melt.
I think it's more accurate to think of cemented carbide as WC particles
soldered together with a Co filler. Little diffusion or dissolution takes place, it's primarily a metal-ceramic interface. (I don't know the mechanics of these sorts of bonds. They certainly seem strong enough, as many cermets can attest to. It's some kind of mixed ionic, covalent or metallic bond -- for sure, orders of magnitude stronger than just proximity (van Der Waals) forces.)
In turn, when you braze an insert to a tool, you're using a brazed joint, which will have some Co and filler (and Fe (or other base metal) and filler) interaction on each joint, and that will probably be more intimate than a sharp (non-diffusive) interface. Typical fillers are in the Cu-Ag-Zn family (including yellow brass, "silver solder"*, and low-melting "silver solder") and Ni-Ag (or Ni-B I've heard of, too) family. These fillers and base metals all have mutual solubility.
*By convention these are called "silver solder", but they're actually braze. Go figure. So I'm quoting them for clarity.
Soft soldering, is typically done at such a temperature and rate, that the diffusion layer is very thin, and this is usually a good thing as a lot of soft solders and base metals have brittle intermetallics that, if allowed to grow, would weaken the joint. The Cu-Sn system has a lot of these; some are very strong (mostly on the Cu side, hence what's so great about bronze), but the intermediate ones tend to be weaker. You can also soft solder metals that are very different indeed, e.g., Ti with Sn filler (if you don't mind the extremely toxic and corrosive flux required
). Although this is a neat example, as Sn is standard in a number of Ti alloys, having an analogous effect as, say... Cr in Fe, maybe?
Intermetallics aren't obligatory, though. Cu-Pb is a nearly immiscible system (no intermetallics, only a little solubility of Cu in Pb at various temperatures, and vice versa; separate liquid phases until quite high temperatures), but it's just fine for soldering. Again, it's not that there's necessarily a diffusion reaction (reaction as in, intermetallics are formed), or necessarily dissolution even, just that the atomic bond at the interface is usefully strong.
Now, I could imagine a rough surface -- lots of "tooth", and lots of microscopic surface area -- is more suitable for soft soldering, given the tendency for intermetallics, or for weak interface bonding -- this might be interesting to test, and is pretty easy to do. Prepare some metal surfaces, of various metals (say, Fe, Cu, Al, Ni would be interesting?), prepare joints with various fillers (Sn100, Pb100 and Sn63 might be interesting datapoints), and test the tensile and shear strength. Also, for surfaces that are prepped with strong linear grooves (e.g., 150 grit + belt sander), it would be interesting to test them in parallel and crossed orientations; and for shear, testing groove to shear force angles as well.
Polished surfaces are tricky. It's easy to make a smooth surface (just apply finer and finer grits), but it's a heck of a lot harder to get planar surfaces at the same time. It might be practical to start with some gage blocks (as awful as it feels to suggest defacing their precision ground surfaces
), since those are lapped and polished to very good planarity. You would be able to ensure micron-thick filler layers in that case (you'd also run the risk of fusing the blocks together -- essentially liquid phase sintering -- if the diffusion layer is allowed to grow too much!), and can modify the filler or gap or surface or clamping to test thicker layers as well.
Clamping pressure in the soldering fixture would also be relevant.
I do recall it's supposed to be that epoxy bonds best with a couple thou gap, and glass microbeads can be added to ensure this gap. I don't know if that might vary with material being bonded, or what. I wonder if solders do the same thing.
Definitely lots of room to test fairly simple things. No idea if these have been evaluated before. I'm sure there's a lot of literature out there on soldering; you'd have to peruse the ASTM or other libraries to see. (May have free access at a school library?)
