So how much noise do you think the LED Driver produces? I think one of the original points in this thread was avoidance of the noise issues pertaining to lights fluorescent in nature. >> just curious
There are multiple potential noise issues from lighting, in the context of an electronics development lab, where you might be working with sensitive circuitry. The sources are:
1. The ordinary mains wiring in the room. Radiates at 50Hz plus harmonics due to any sine distortions from nearby loads, plus noise conducted in on the wires from noisy loads in the neighborhood.
2. Noise radiated from the light fitting/tubes & wiring. Mains fluorescent tubes are inherently noisy due to being a long arc. And that's ignoring the high voltage spikes during starting. Cold cathode tubes as in LCB backlights use drive voltages of several KV, so are extremely bad.
3. Switching noise radiated from any light that uses a switchmode supply. This can be direct from the supply, and also coupled into both the input and output wiring as antennas. With commercial units you take what you get. With a properly designed and constructed unit this can be eliminated.
For most electronics development none are these sources are a concern. But if you want to do very low voltage high impedance work, it is an issue. It's one reason I recently added old fashioned transformer-driven 12VAC halogen ceiling lights to my workspace - now if I want to I can turn the fluorescent battens off, and just use the halogens. There's still the 240VAC to the power points, but that can be isolated by turning off the breaker elsewhere. That said, I'm in no way trying to achieve full Faraday Cage shielded room effect.
With the LED striplights, they're for a bench to be almost exclusively used for soldering, so I can't see noise there being a problem. But just on principle I'll design the drive circuit to not radiate RF. Good mains filter on the input, metal case, PF correction input stage, then all LV wiring well filtered before leaving the box. The wires to the LED strips will carry only clean DC. Same with the wires to the two control pots, if they are not on the actual drive box.
Incidentally, I don't know about contemporary digital scopes with LCD screen backlights, but a couple of Tek ones I used about a decade ago were appalling. Unusable for low voltage analog work, imo. The screen backlight was cold cathode and apparently unshielded in the plastic scope case, resulting in multiple millivolts of 30-40KHz noise pickup in all circuits on the bench anywhere near the scope.
