Author Topic: Soldering station recommendation  (Read 528 times)
Offline bottlegardenerTopic starter
« on: April 19, 2024, 09:08:21 pm »
Hi all,
I'd like a second soldering station as I'm getting tired of moving my beat-up Weller WES51 between two locations. I have a vague notion that much has changed technology-wise in the intervening 18-odd years since I bought the Weller. I'm a bit overwhelmed. I was just wondering if anyone has any recommendations for an inexpensive (under $200, cheaper is better) station?
I work on mostly old audio equipment and old cameras. Everything is through-hole. It nearly all uses lead solder. I sometimes have to work on flexible PBCs and primitive PCBs with traces that easily lift. On the other end, I sometimes need to solder wires to stainless steel battery contacts (for which I typically use Rubyfluid and thoroughly clean afterwards) or braided chassis ground wires on guitar amps. Other than that it's all pretty basic stuff (patchbays, cables, ordinary through-hole PCBs).
Any recommendations would be much appreciated. I'm particularly curious if any of the cheap Aliexpress would suffice.
« Last Edit: April 19, 2024, 09:19:26 pm by bottlegardener »
Offline thm_w
  • Non-expert
Re: Soldering station recommendation
« Reply #1 on: April 19, 2024, 09:19:58 pm »
For your budget you are probably looking at a t245 clone station.
T12 clone would be cheaper still, but you'd give up a bit of performance.
https://www.youtube.com/@sdgelectronics/search?query=soldering
https://www.eevblog.com/forum/other-blog-specific/the-sdg-electronics-soldering-station-comparisonshootout-thread/
The following users thanked this post: SteveyG, bottlegardener
