Hi, I wrote a little summary just to have a point of reference, maybe the main choices are three, I choose a soldering station compatible with
T12 tips or a station with
900M tips which are quite widespread, or I also evaluated the soldering stations compatible with
C245/T245 tips.
From what I know the T12 tips were developed by Hakko also called T15 as well as the 900M then replaced by the T18 always by Hakko, and the C245 instead were developed by JBC, since the Chinese have copied this technology consequently almost all the low-cost stations that use this kind of tips are in fact of Chinese production
The T15s are not interchangeable with the T12s, they are shorter and have steps that prevent them from being mounted in a T12 handle.
Obviously the T12 and C245/T245 cartridge tips have superior performance and quality compared to the old 900M, the only problem is that most of the Chinese clones have a low construction quality.
The soldering stations that I found at an affordable price compatible with T12 tips are:
Axun T3A,
Quicko/Quecoo,
KSGER,
Yihua 948DB,
AIFEN A8,
Bakon BK969D,
GEEBOON TC20A,
Bakon BK950DThe Yihua 948DB is also available on Amazon, as for construction quality is it superior compared to Aixun, Quicko, KSGER ?
Regarding Quicko or KSGER there is the advantage that the mini versions are available with the 24v power supply separately, so I could buy a quality 24v power supply separately, in case of problems it would be very simple to replace the power supply, what do you think ?
https://it.aliexpress.com/item/32857152188.html?spm=a2g0o.store_pc_allItems_or_groupList.0.0.1b744ff9Faj5JY&pdp_npi=4%40dis%21EUR%21%E2%82%AC%2040%2C41%21%E2%82%AC%2028 %2C29%21%21%2143.86%2130.71%21%40210385a817256920521122226e80c7%2165279967789%21sh %21IT%210%21X&gatewayAdapt=glo2itahttps://it.aliexpress.com/item/32843974498.html?pdp_npi=4%40dis%21EUR%21%E2%82%AC%2026%2C49%21%E2%82%AC%2026%2C49%21%21%2128.75 %2128.75%21%402103892f17257629964232661eef0a%2165143158715%21sh%21IT%210%21X&spm=a2g0o. store_pc_allItems_or_groupList.new_all_items_2007586013081.32843974498&gatewayAdapt=glo2ita
https://it.aliexpress.com/item/32839523934.html?spm=a2g0o.productlist.main.11.7ebaVnxYVnxYuF&algo_pvid=4e4a7 e8e-ba54-4875-8afc-2aded311e1b0&algo_exp_id=4e4a7 e8e-ba54-4875-8afc-2aded311e1b0-5&pdp_npi=4%40dis%21EUR%2139.43%2131.14%21%21%2142.79%2133.79%21%40211b8c6217257631844993506e4a6c% 2110000002010599225%21sea%21IT%210%21ABX&curPageLogUid=mTC1T8obfhTW&utparam-url=scene%3Asearch%7Cquery_from%3A
Stations soldering irons C245/T245 :
YIHUA 982,
AIFEN-A3,
Aifen A9,
SUGON-A9,
SUGON T21,
AiXun T320GVM T245,
GEEBOON TC20A,
982-I, Aixun T3A,
KSGER C245 The Aixun T420D has a linear transformer but it is too expensive.
The stations compatible with 900M tips with the linear power supply in my opinion are more resistant:
Atten AT938D,
YIHUA 937D,
YIHUA 939D+,
YIHUA 939D+ III,
ATTEN ST80Instead the various Ningbo Zhongdi and Lafayette do not have the 900M tips but the technology is always that of the ceramic heating element that enters inside the tip, the tips and handles are easily available and have the linear transformer:
ZD-931,
Lafayette SDD-9Cartridge soldering stations with the linear power supply:ATETOOL AE970,
Quick ts1100,
Quick ts1200,
mechanic c211,
Aixun T420D, WEMON T31,
GVM H3,
Best BST-933B,
Jabe UD-1200 AiXun T413,
WEP 982D One of the few soldering stations with the linear transformer and cartridge tips that I have found is the ATETOOL AE970D, but it uses a T80 tip, it is a bit difficult to find.
The Quick ts1100 also uses cartridge tips, it should have the linear power supply inside but I am not sure, it is present instead on the Quick ts1200
Here's a complete summary:
Soldering Irons CXG E60WT E90WT
Tips: 900M
CXG 936d
Tips: 900M
CXG 900M soldering tip compatible with E60S/90S/110S/E60WT/E90WT
MULTICOMP PRO MP740061
Tips: MULTICOMP PRO
Tip: T900
Manufacturer: ATTEN ST-2065D
RS PRO 202-4536
Tip: RS PRO
Tips: T900
MINIWARE TS101
Pinecil V2
Tips: TS100 - Pine64
Atten ST-2065D
Atten SA50
Tips: 900M
TQ-95-CE
Tips: GOOT TQ-77 RT series
Antex ER30
Tips: ER30 series
Ersa 30s 30w
Tips: Ersa 832, 842, 852 series
JBC 30ST
Tips: JBC 30ST/40ST/SL2020/IN2100 series
Soldering StationsSoldering Stations with Linear Transformer: TENMA 21-10115 EU
RS PRO 202-4512
Manufacturer: Atten AT938D
Compatible Tips: 900M, RS PRO, TENMA
ZD-931, ZD-929B, ZD-929B, Fixpoint 51098, Lafayette SDD-9, Fixpoint 51098, LS-450 digi, Transmedia ZLS2L, DURATOOL
D00678, DURATOOL D00661
Manufacturer: Ningbo Zhongdi-Lafayette
Tips: ZD series (ZD-931, ZD-937, LS-450, LS-1000, SSD9, WS937, ZD929A, ZD929B, ZD929C, SSL-2, SSD-3)
ELE-ATS1
Manufacturer: ATETOOL AE970D
Tips: T80
Handle: AH809
Aoyue 937+
Handle: 907ESD
Aoyue 9378
Handle: B033-P
Tips: 900M
Yihua 936
Handle: 907A
YIHUA 937D
Handle: 907A
YIHUA 939D+
Handle: YIHUA 907E
YIHUA 939D+ III
Handle: 816D
Tips: 900M
ATTEN AT80D
Tips: 900M-T-I
Handle: AP-80
ATTEN AT938D
Tips: 900M-T-B
Handle: ATTEN AP-60
ATTEN AT937A
Tips: 900M-T-B
Handle: ATTEN AP-50
ATTEN ST80
Tips: 900M
Handle: ATTEN ST-80
ATTEN AT-989D
Tips: T900-B
Handle: ATTEN AP-65A
Tips: 900M/T900
Atten ST-965
Tips: T900
Handle: ATTEN ST-965
MULTICOMP PRO MP740261
Manufacturer: Atten ST80
Tips: MULTICOMP PRO
Tips: 900M
Tilswall
Proprietary tip type
Mechanic C211
Handle: T210
Tips: C211, C115
Quick TS1100
Handle: TSS30A
Tips: 960 series, Quick 960
AIXUN T420D
Tips: C210, C115, C245
Handle: T210, T115, T245
WEMON T31
Tips: C115 C210 C245
Handle: WEMON T245, WEMON T210, WEMOM T115
GVM H3
Tips: C210/C245/C115
Handle: 210/T245/T115
Best BST-933B
Tips: C245
Handle: 2245-A BST
Jabe UD-1200
Tips: C245
Handle: 2245-A UD
WEP 982D
Tips C245/C210
Handle: WEP 616A, WEP 716A
AiXun T413
Tips: C245/C225
Handle: T245/T225
Soldering Stations with Switching Power Supply: Aoyue 3210
Handle: 907A
Tips: 900M
YIHUA 926
Tips: 900-B-900M
Non-removable handle
YIHUA 939D+ III
Handle: YIHUA 816D
Tips: 900M
Xytronic LF-389D
AIFEN-A3
Handles: T210/T245/T115
Aixun T3A
Tips: T12, 936, and T245
Handles: T245/T12
AiXun T320
Tips: C210/C245
Handles: T210 T245
Quicko T12-942
Tips: T12
Handles: T12-907-T12-9501
KSGER T12 STM32 V3.1S
Tips: T12
Handles: FX9501-T12 907
KSGER C245
Tips: C245
Handle: T245
Yihua 948DB
Preciva 948DB+
Tips: T12
Handle: YIHUA 506A
SUGON T21
Tips: C210/C245/C470/C115
Handle: T245
AIFEN A8
Handle/Tips: T12
SUGON-A9
Handles: T115/T210/T245
Aifen A9
Handles: T245/T210/T115
YIHUA 982
Tips: C210 and C245
Handles: 616A/716A
JCD T210
Tips: C210
Handle: T210
Bakon BK969D
Tips: T12
Handle: Bakon LF008
GVM T245
Tips: C245
Handle: T245
GEEBOON TC20A
Tips C245/C210/C115/T12
Handle: 115/210/245/T12
982-I
Tips: С210/С245
Handle: 706A/606A
Bakon BK950D
Tips: T12/T13
Handle: LF007
Which model do you think I should purchase ?
