Author Topic: Station choices for 10awg and Connectors  (Read 3832 times)
Offline Ty89mTopic starter
« on: June 21, 2024, 09:08:35 pm »
Hey all,
I'm in the market to upgrade my soldering station and I'd love some feedback on my options given my intended use case.
I'm mainly an RC hobbyist - soldering/tinning 8-14awg wire and bullets/connectors and directly to large tabs on brushless motors. I also dabble in amp and guitar pedal building, but most of my stations have performed well enough on smaller jobs such as these.
I currently run a Xytonic LF3200 120W station, but I'm due to replace the tips and I'm itching to try something new. Obviously my main goals are making quicker work of large gauge wire tinning and connector soldering, so I've picked three stations that would likely fit the bill.
The ADS200 Plus, which I've been meaning to try for a few years now, and see they've released an updated version. Seems to be a great value option with affordable tips.
JBC CD-1BQF. The most expensive option, and likely overkill, but I'm fine with it.
Thermaltronics TMT-2000-S with K series tip. Most affordable option, but could step up to the 9000 series, though it doesn't sound like I'd be missing too much by going with the more affordable 2000 series.
If anyone has direct experience with these systems doing similar soldering jobs, I'd love to hear your feedback/recommendations!
Thanks from a long-time lurker.
The following users thanked this post: marck120
Offline thm_w
  • Non-expert
Re: Station choices for 10awg and Connectors
« Reply #1 on: June 21, 2024, 09:44:22 pm »
JBC T245 (official or clone) or Metcal PS5000/5200 (80W).
Thermaltronics is only 40W, will work OK, but not as great as 80W. You'd have to look at some of SDGs older reviews to see how 40W compares to jbc.
Don't bother with ADS200 plus until someone proves it has improved at all.
Either way get a 5 or 6mm tip and make sure its super short for best thermal transfer ability. Probably worth getting a genuine tip.
The following users thanked this post: Someone, Ty89m
« Reply #2 on: June 22, 2024, 08:18:28 pm »
I'm leaning JBC as a good compromise on price vs. performance. The MX-500 or Thermaltronics 9000 are still in the running, but the 5200 is hard to justify for my intended use. I do like the idea of not having to worry about calibration when using the Metcal/Thermaltronics units, as investing in a tip temp sensor is an added expense I'd prefer to avoid - that said, I'm not soldering mission-critical components here, so absurd accuracy likely isn't necessary anyway.
I just want to get in/out without overheating wires (I'm trying to avoid wicking solder up the wire/insulation), and yes, I'll be using large chisel tips for the most part.
Online David Hess
  • DavidH
« Reply #3 on: June 22, 2024, 09:28:45 pm »
I regularly do 10 AWG with my old 60 watt Weller WTCPT with a fatter 700F tip, and I doubt 8 AWG would be any more difficult, so I am not sure what you are looking for.
If you need more performance, maybe get a fatter tip for your existing iron.
« Reply #4 on: June 23, 2024, 12:08:56 am »
As can I with my current system and my old FX888, but I know there are better-performing setups these days, and I'd like to see what Metcal/JBC are all about. Perhaps I'll find little benefit, but at least that itch will be scratched.
Offline wraper
  • Country: lv
« Reply #5 on: June 23, 2024, 12:17:41 am »
I don't see why you'd ever need any calibration unless you want to verify/standardize conditions at every seat in production environment. Not to say Metcal cartridge temperature accuracy spec is not better than of any decent resistive soldering station.
https://www.metcal.com/wp-content/uploads/2021/02/Metcal-Maximum-Tip-Temperature_ver-2.pdf
The following users thanked this post: helius
Offline johansen
« Reply #6 on: June 23, 2024, 01:48:24 am »
I know from experience that while the wattage of the soldering iron is important, what really matters is the thermal conductivity of the soldering iron. The stored heat in the tip at 300-400F above the melting point is pretty significant.
Two 10 ga wires together is ok, with my 60watt hakko using the fattest 1$ chinease tip, which probably does not have much copper in it. Ive probably done two #8's
I would speculate that if you took an arc welder and fused together the strands of a 6ga wire, then splayed out the strands, straightened them out, fit them around the ceramic heating element in your soldering iron, you could solder 2 6ga wires together at with 60 watts of heat..
A nickel plating kit is 30$ these days ..
« Last Edit: June 23, 2024, 01:54:34 am by johansen »
Offline coppercone2
« Reply #7 on: June 23, 2024, 01:52:16 am »
their iron clad. Nickel plated tip sounds suspicious. There are nickel bearing solders. I think it would contaminate.
Clad usually means its not made chemically, but its made through heat and pressure.
Offline johansen
« Reply #8 on: June 23, 2024, 01:58:54 am »
The iron is to prevent the tip from dissolving.
Nickel plating your own solid copper tips works.. but it doesnt last long. The nickel may reduce the ductility and fatigue resistance of your joint, but that is a problem for satellites and aircraft, not you. It will be difficult to measure.
You can use up a whole pound of solder in hundreds of 6 to 8 ga wire solder joints before you wear out a diy nickel plated copper tip.
My experience is legit 700F weller tips last half to 3/4  pound of 97% tin 2% silver 0.7% copper solder, soldering around 5000 solder joints.
The 800F tips dont last long at all. 600 works for me but is too slow
And yes the dissolved iron will also contamination your solder... Take a guess whats under the iron... Nickel!!
« Last Edit: June 23, 2024, 02:09:36 am by johansen »
Offline Someone
    • send complaints here
« Reply #9 on: June 23, 2024, 02:35:24 am »
They're different in the way they achieve it but for your bulk use cases they boil down to having a more tightly regulated temperature.
Power is what you really need to pay attention to on such large cables and I agree with the above that you want to avoid a station that only delivers 40/50W and get something up 80/90/120W.
Everything old is new again and there are high thermal capacity tips for both systems (the original selling point of tight control, not needing bigger tips) which can help.
Online David Hess
  • DavidH
« Reply #10 on: June 23, 2024, 11:59:34 am »
My Weller WTCPT stations are all 60 watts and do 10 AWG easily with their fat short tips, so 8 AWG should work.  I do have a 100 watt Weller temperature controlled iron for heavier jobs, but I rarely need it.  I used it recently for soldering MIG welding cables.
https://www.amazon.com/Weller-Soldering-Iron-Stained-Supplies/dp/B013P45OQ2/
Offline wraper
  • Country: lv
« Reply #11 on: June 23, 2024, 12:14:14 pm »
What matters the most is not power rating as such but heat transfer from the heater and tip thermal mass that mitigates insufficient heat transfer. That's why you cannot solder heavy things with small tips despite how powerful is the heater. With less that 5mm chisel it does not really matter if iron has more than 50W. That's why the most important thing is tip/heater (cartridge) construction, and the best stations can push more heat through the same size of the tip than inferior ones.
Offline Someone
« Reply #12 on: June 23, 2024, 09:54:37 pm »
Baloney, it's about how well the power can be delivered to the solder/joint. Heaters right at/in the tip like Metcal and JBC can deliver their power without the need for thermal mass.
Offline coppercone2
« Reply #13 on: June 23, 2024, 10:00:24 pm »
use resistance tweezer
but for big connector you want one of the tougher units, the pace is efficient but if its the load is too big it sucks
but if you carefully stuff your connector with solder, you can get picturesque connectors without a lub of solder on the side from the iron
they are the ultimate thermal delivery system, other then induction.
« Last Edit: June 23, 2024, 10:02:56 pm by coppercone2 »
Offline wraper
  • Country: lv
« Reply #14 on: June 23, 2024, 10:14:13 pm »
Dude, did you actually read what I wrote to call it baloney? I literally wrote that heat transfer is what matters. :palm:  |O Also thermal mass still matters because heating response is not immediate even in JBC. BTW heater is not right at the tip, there is significant distance, and that's why JBC has normal and High thermal cartridges of the same size (the downside is worse reach in tight places).
« Last Edit: June 23, 2024, 10:20:24 pm by wraper »
Offline Someone
« Reply #15 on: June 23, 2024, 10:19:36 pm »
There is no need to add thermal mass to "fix" inadequate coupling from the heater to the joint. It is one possible solution just as adding more power and temperature to compensate for a temperature drop along a tip heated from one end.
or..
Solve that with a heater in intimate contact with the joint, which can have less thermal mass. Metcal uses microsecond timescale thermal control, pretty much instantaneous/immediate.
Online nctnico
« Reply #16 on: June 23, 2024, 11:14:33 pm »
Agreed. In addition: a small tip won't be able to transfer a lot of energy anyway because the thermal conductance from heater to the tip is not low enough. JBC tries to compensate by sending too much power to the tip but this results in poor temperature control and tips which go bad quickly. Bottom line: soldering big joints requires big tips.
The following users thanked this post: wraper
Offline Someone
« Reply #17 on: June 23, 2024, 11:48:34 pm »
Says you.
I've a Metcal right in front of me with "high thermal mass" variants of tips so I can compare them side by side. Imperceptible difference to me. Solders the same on massive heatsinks like thick cables or solid plates. Oh and there is a handy power meter to show when its running out of steam.
Some of us are fine acknowledging other ways of doing things. Others insist there is only one (which is not always true).
Offline wraper
  • Country: lv
« Reply #18 on: June 24, 2024, 12:00:23 am »
Then your "thick" is not thick enough or your skill sucks enough to not see the difference. If there is no difference, why do you think such tips/cartridges are produced to begin with?
Offline Someone
« Reply #19 on: June 24, 2024, 12:10:05 am »
Seems to be marking puffery to me, the manufacturer claims there is a benefit:
"A new line of tips for the TMT-9000S, Thermaltronics M Series Power Plus tips offer higher performance and longer tip life to our users."
But I've been unable to see any significant difference in use and there is a distinct lack of marketing or literature to support the additional mass adding anything useful.
What do people want? Stable temperature of the solder joint. There are many things which contribute to that and adding thermal mass can be detrimental if that is increasing the loss or reducing coupling from heater to workpiece.
Offline Someone
« Reply #20 on: June 24, 2024, 01:49:42 am »
Since I have some M series tips here and there has been some heated discussion I went ahead and tested them on a 12 AWG wire terminating into a ground plane on a sizeable PCB.
https://www.thermaltronics.com//datasheet/M7CP303
https://www.thermaltronics.com/datasheet/M7CH176
https://www.thermaltronics.com/datasheet/M7CH176H
All pulled approximately the same power ("29" to "31" as reported by the Metcal 5000, not consistent between tips across multiple repeats) when pressed against the joint. Larger joints do increase the power reading further.
Offline Arts
« Reply #21 on: June 24, 2024, 02:39:12 am »
I have several stations that work extremely well for heavy-duty applications. The price ranges (including tip pricing) vary from fairly reasonable to ridiculous :)
Hakko FM203 station with FM-2030 wand and T22 140W tips. An absolute monster, and with the 5.2mm chisel tip you could probably take a crack at plumbing pipes...
As this is a two-port station, I have the regular duty FM-2027 wand and T15 70W tips in the other channel.
JBC CD-1BE with C245 High Thermal Efficiency 6.6mm chisel tip. 130W peak power, whatever that means. Another monster.
Metcal PS-900 with 5mm SCV chisel tip. For such a tiny, inexpensive no-frills station with such a low-power rating (60W?!) this thing is amazing.
Online tooki
« Reply #22 on: June 24, 2024, 06:46:43 am »
There is also the 250W Ersa Power Tool, which works with the Vario line of stations IIRC.
With that said, I agree with everyone who thinks that the 120W you have now is enough, and that getting bigger tips would probably do more for you.
Or look at something completely different: resistance soldering. That is great for big connectors and whatnot because all the heat is generated right within the workpiece itself. The two vendors I’m aware of for such equipment are Pace and American Beauty.
Online bdunham7
« Reply #23 on: June 24, 2024, 07:54:06 pm »
I don't have the "plus" version but I doubt very much that even the ADS200+ is a good choice for large thermal mass soldering jobs, even with the Ultra tips and "improvements".  It's a very nice setup for normal work but I would bet that even the new Hakko FX888DX with the FX8806 95W iron would beat it for large work.  Perhaps someone will review the ADS200+ someday.
To get jobs like that done quickly you either want a huge iron with extreme thermal mass (I'd recommend a diamond-shaped tip) or resistance tweezers.  You don't really need fine temperature control as you'll be using speed, skill and the melting of the solder to limit temperatures.
https://americanbeautytools.com/soldering-iron-3138/15/features
https://americanbeautytools.com/Resistance-Tweezer-Systems/102/features
Offline thm_w
  • Non-expert
« Reply #24 on: June 28, 2024, 12:55:24 am »
https://www.thermaltronics.com//datasheet/M7CP303 - 1mm conical
https://www.thermaltronics.com/datasheet/M7CH176 - 1.78mm chisel
https://www.thermaltronics.com/datasheet/M7CH176H - 1.78mm power chisel
Added description above to your post. Good measurements that do demonstrate how well metcal works with smaller tip sizes. Though there will still be a physical limit when we reach a certain: temperature differential, surface area, and thermal conductivity. Grab something like long reach STTC-140 or a fine point STTC-126 and it will be obvious, you'll only transfer ~20W. Compared to the 30-40W you saw.
Agree that the thermaltronics "power plus" tip is a gimmick. It probably has some niche use case, but, for any hobbyist its not useful to buy them. They are worse for the kind of stuff we do (heavy, slow to heat up).
Considering you can get a wide M7CH250 (STTC-117) or M7CP200 (STTC-136P) for $17 though, it may be worth having around.
