What do you expect shifting to? You should already know he encoder ledt-rotation it's for entering low power modes.
You can't enable any higher power mode with the encoder while in stand mode, in any case you need to remove the stand.
If the sleep/standby timer expired while the handle was put, you need to put the handle in for a moment to reset the state.
You are not supossed to use low timeouts for stand mode, that's more like a safety timeout, as you normally put the handle in and out all the time.
If by any reasons the handle is forgotten or doesn't make contact with the stand, the timeout will be still counting, entering sleep/standby.
Stand mode works perfectly here. I can remove and put the tip a thousand times.
Of course, it goes into sleep when there's no tip, showing NO IRON error.
Do you want to exit sleep mode when you dont have tip? Does that make any sense tyo you?
It returns to normal mode when the tip it's plugged back.
Please take seriously what I said, make proper reports. Not just "hmm it does something strange".
Test it, what, when and how it happens and then report. Otherwise I'm gonna start blowing hot air again
