Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 917774 times)
Offline rokko
  • Country: ua
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #3475 on: June 19, 2023, 07:49:31 pm »
Thanks, gonna make it this way.
Offline asupsp700
  • Country: ua
« Reply #3476 on: June 20, 2023, 05:37:14 am »
Hello. board KSGER v2.Firmware penultimate. Tell me why the current temperature is not saved? Saving a profile in the menu is enabled. There is a battery. The battery voltage is 3 volts. The tip type is saved but the temperature is not...
Online DavidAlfa
« Reply #3477 on: June 21, 2023, 04:49:51 pm »
Not enabled by default, but there's flag to enable that.
Follow the firmware building instructions, uncomment this line (Remove the "//") before running the building script, after compiling the new firmware will be available in BOARDS/KSGER(...) folder.
The following users thanked this post: asupsp700
Offline ststefanov13
  • Country: bg
« Reply #3478 on: June 23, 2023, 02:35:32 pm »
My question is, David, is it possible to disabled temprorary standard function of the tilt switch input and make an addon (for example, through an addon more similar to fume_extractor ) and repurpose it for a desoldering module to control a valve or pump as it is in the original Chinese firmware (eg when N tips are used) ?
Look at the picture....
« Last Edit: June 23, 2023, 05:40:28 pm by ststefanov13 »
Online DavidAlfa
« Reply #3479 on: June 23, 2023, 06:44:57 pm »
Everything is possible, but not me doing it, I'm just too busy!
The following users thanked this post: totalnoob
Offline asupsp700
  • Country: ua
« Reply #3480 on: June 24, 2023, 02:11:30 pm »
Good day to all. Got the station. The screen used 2.42 inches. April firmware .... I hear a small squeak from the display. Probably the throttle on the display board beeps. You can somehow remove the squeak. My screen settings. Thanks to all!
Online DavidAlfa
« Reply #3481 on: June 24, 2023, 02:50:23 pm »
Hard to tell. Try adjusting the advanced display settings!
Offline asupsp700
  • Country: ua
« Reply #3482 on: June 24, 2023, 03:00:10 pm »
Is it possible to damage the display by changing the settings?
« Last Edit: June 24, 2023, 03:28:18 pm by asupsp700 »
Online DavidAlfa
« Reply #3483 on: June 24, 2023, 08:00:28 pm »
No, you could get a corrupted image, but the controller will still work, so just keep rotating until it looks nice/better or rotate backwards.
Nothing is saved unless you manually click on SAVE, in the worst case just turn the station off / on and keep trying different settings.
Offline asupsp700
  • Country: ua
« Reply #3484 on: June 25, 2023, 12:27:39 am »
I expressed myself incorrectly. Can I reduce the life of the display with my settings? Are your default settings the optimal settings for the SD1309?
Online DavidAlfa
« Reply #3485 on: June 25, 2023, 11:58:21 am »
The only thing that can reduce display life is high brightness for long time, these displays will usually die after 2 years if working 24/7.
Nothing to worry about, just use it normally  :-+
Optimal settings are relative, there are many displays!
I used something that seem to work with everything.
But you might find it looks brighter changing them.
« Last Edit: June 25, 2023, 12:03:41 pm by DavidAlfa »
Offline maizang53
  • Country: hk
« Reply #3486 on: June 26, 2023, 06:43:22 am »
I have the latest version of the source code on my end
Based on MM32SPIN27PF microcontroller
If the moderator is interested, I can provide it to you
Online DavidAlfa
« Reply #3487 on: June 26, 2023, 08:33:51 am »
What source code? From the original firmware?
Offline asupsp700
  • Country: ua
« Reply #3488 on: June 26, 2023, 05:15:45 pm »
Yes, that's the tip detection routine, before reading the TC it outputs a very short pulse.
Normally it's barely noticeable, but reducing ADC time will make it noisier.
If you added a 1M resistor between Heater and 3.3V (Or 10M across the MOSFET drain and source) then you can disable the "Active detection", noise will go away.
I only use C245. What is the principle of the active detection function if you solder a 10MΩ resistor between the drain and source of the transistor? In 245, there is a separate wire from the thermocouple..... Or does it only work for T12 tips, where the thermocouple is in series with the heater?
     Sometimes a fictitious temperature jumps on the display when the sting is pulled out - I want to get rid of this defect .... Do I need to pull up the input of the operational amplifier by 3 volts through a 1MΩ resistor? ..
« Last Edit: June 26, 2023, 05:44:29 pm by asupsp700 »
Online DavidAlfa
« Reply #3489 on: June 26, 2023, 06:09:21 pm »
It prevents the amplifier input from floating and jumping around showing random temperatures when the tip is removed.
Offline maizang53
  • Country: hk
« Reply #3490 on: June 27, 2023, 01:56:44 am »
The new version of 3.1S is based on the original firmware of MM32SPIN27PF
I am a manufacturer of KSGER in China
We are currently designing a new version of the T12 handle
« Last Edit: June 27, 2023, 02:10:57 am by maizang53 »
The following users thanked this post: ricktendo
Online DavidAlfa
« Reply #3491 on: June 27, 2023, 02:01:56 am »
Interesting, could you upload it?
Offline maizang53
  • Country: hk
« Reply #3492 on: June 27, 2023, 02:11:55 am »
Give me your email and I will send it to you separately. Uploading here is not very convenient
Online DavidAlfa
« Reply #3493 on: June 27, 2023, 02:20:15 am »
Just use www.anonfiles.com and send me a private message with the link  :-+
Offline ricktendoTopic starter
  • Country: hn
« Reply #3494 on: June 27, 2023, 09:48:45 pm »
New handle looks nice, but the tip to grip could be a bit shorter.
Offline totalnoob
« Reply #3495 on: June 27, 2023, 10:19:29 pm »
I have the stainless steel handle and the gripe I have with it is that there is no positive stop that you can feel the tip has seated and I have pushed the strain relief out of the back because I pushed the tip in too far. I recommend having a positive stop, even if there is no "feel" for seating the tip, to at least stop from pushing the tip in further.
Other than that request, I do like the look of the new handle.  :-+
Offline maizang53
  • Country: hk
« Reply #3496 on: June 28, 2023, 01:15:46 am »
There is a limit at the rear end of the handle
Fix the position of the heating core
The position indicated by the arrow in the picture
Now there are already sales in KSGER's flagship store
Nylon material
Considering designing all metal or semi metal materials
If it is made of all metal materials, poor insulation can cause burns to the hands
However, metal materials can achieve contact dormancy
Offline maizang53
  • Country: hk
« Reply #3497 on: June 28, 2023, 01:18:46 am »
Because I am in China and some websites are not open enough, it is better to give me an email address
You still need to pay for opening this link now :(
Online DavidAlfa
« Reply #3498 on: June 28, 2023, 03:48:37 am »
Pm sent  :-+
Offline maizang53
  • Country: hk
« Reply #3499 on: June 28, 2023, 03:58:10 am »
