Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 952756 times)
oleg401169, ladimir and 5 Guests are viewing this topic.
Offline maizang53
  • Country: hk
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #3500 on: June 28, 2023, 04:53:30 am »
I sent a link to a cloud disk for you to try
Offline DavidAlfa
« Reply #3501 on: June 28, 2023, 05:08:41 am »
You asked me for the e-mail,  just use it ;)
Offline maizang53
  • Country: hk
« Reply #3502 on: June 28, 2023, 10:59:28 am »
It has been sent with another email address, please check
Offline DavidAlfa
« Reply #3503 on: June 28, 2023, 01:04:33 pm »
Got it, thanks!
Will have a look at it, but just for curiosity, I don't have time for anything! :)
The following users thanked this post: maizang53
Offline asupsp700
  • Country: ua
« Reply #3504 on: June 30, 2023, 08:12:08 am »
Good day to all. Got the station. The screen used 2.42 inches. April firmware .... I hear a small squeak from the display. Probably the throttle on the display board beeps. You can somehow remove the squeak. My screen settings. Thanks to all!
Everything was decided. I forgot about the resistance on the board of 10 ohms to power the display ... The voltage dropped and the inductance on the display began to squeak :). Now, instead of resistance, I put smd inductance - everything is fine! - The squeak is gone, the brightness is excellent!
      Can I somehow change the picture on the screen of the T12 sting to C245? I use only C245 - I want it to be right :)
Offline DavidAlfa
« Reply #3505 on: June 30, 2023, 08:39:18 am »
I never saw that resistor, is it a custom board?
Just power it with 3.3V directly (The inductor is fine).
The following users thanked this post: asupsp700
Offline asupsp700
  • Country: ua
« Reply #3506 on: June 30, 2023, 09:12:19 am »
Boards are sold by a person in Ukraine. I bought a bare board from him ... I soldered the details myself ... I soldered the inductance just so as not to put a jumper  ;)...
« Last Edit: June 30, 2023, 09:16:24 am by asupsp700 »
Offline asupsp700
  • Country: ua
« Reply #3507 on: June 30, 2023, 09:30:55 am »
More photos....
The following users thanked this post: ststefanov13
Offline DavidAlfa
« Reply #3508 on: June 30, 2023, 12:24:53 pm »
You can make your own picture using Paint in B&W mode, save it to png or bmp and convert to xbm.
Edit the xbm file as text, paste the array content here, modify size if different but I recommend using the same size (105x7).
Compilation.is easy following the instructions from github.
Offline asupsp700
  • Country: ua
« Reply #3509 on: June 30, 2023, 02:26:42 pm »
I will draw  ;)
Offline asupsp700
  • Country: ua
« Reply #3510 on: July 01, 2023, 01:44:01 pm »
Good afternoon David. Tell me what I'm doing wrong .... I tried both version 1.5.1 and the latest 1.12.1. Knocks out an error .... What version of Cube should be installed?
Thank you!
Offline DavidAlfa
« Reply #3511 on: July 01, 2023, 04:28:44 pm »
Did you follow the instructions?
You only need the IDE, not CubeMX.
Latests version should work right.
Did you read this?
Note: CubeIDE (Current version: 1.11.1) needs Java JDK, but won't work with versions newer than JDK15 (Available here).
Also, if you made modifications to the code you might have broken something.
First try with a clean source code!
« Last Edit: July 01, 2023, 04:31:47 pm by DavidAlfa »
Offline asupsp700
  • Country: ua
« Reply #3512 on: July 01, 2023, 06:05:08 pm »
I read the instruction. I'll try again tomorrow on another computer...
« Last Edit: July 01, 2023, 06:10:48 pm by asupsp700 »
Offline DavidAlfa
« Reply #3513 on: July 01, 2023, 07:57:07 pm »
No idea!
You can try by modifying this line to:
start /w /min "CubeIDE" %IDE% -nosplash -application org.eclipse.cdt.managedbuilder.core.headlessbuild -import %cd% -build STM32SolderingStation/%DISP:"=%_Release
That way it should show what's going on.
Or you can do it by importing the project into CubeIDE and clicking the Build button, it's also explained in github.
Offline asupsp700
  • Country: ua
« Reply #3514 on: July 02, 2023, 09:46:18 am »
Hi!
It worked on another computer  :)! Many thanks for the help  :-+ !
Offline asupsp700
  • Country: ua
« Reply #3515 on: July 05, 2023, 10:27:58 am »
David, big request. When you have free time, please add to release 1.09.2 the function of automatic selection of tips when replacing ... In 1.10.2 I don't like that the "Power" scale is reduced :(
Offline DavidAlfa
« Reply #3516 on: July 05, 2023, 12:44:12 pm »
What exactly?
The power bar will stay like that, required to allow longer tip mames.
Offline asupsp700
  • Country: ua
« Reply #3517 on: July 05, 2023, 01:39:18 pm »
I don't need long titles. I like it better when this strip is long :). So I'm sitting on 1.09.2 ...
And the sting selection function seems convenient. Therefore, if it can be implemented in 1.09.2, it would be great!
Offline DavidAlfa
« Reply #3518 on: July 05, 2023, 02:29:44 pm »
Sorry, but I can't make a custom firmware for everyone's personal preference, you'll have to stay with 1.09.2...
I think supporting larger tip names is a more useful feature than a slighly bigger power bar... :-+
Offline asupsp700
  • Country: ua
« Reply #3519 on: July 05, 2023, 02:44:00 pm »
Everything is ok, thanks!
Offline DavidAlfa
« Reply #3520 on: July 05, 2023, 03:24:37 pm »
Nevermind, I barely touched the station all these months so I didn't notice.
But after watching your picture I realized something... there was too much empty space between the tip label and the bar.
Then I remembered! I had tried even larger text, 13 or 10 chars, so I had to reduce the power bar.
The system became unstable and crashed, so in the end I set it to 8 chars... but I forgot to expand the power bar again to use the free space!
So I expanded it again, now it's 52px, still slighly smaller than before (60px), but barely noticeable while keeping the longer tip names.
« Last Edit: July 05, 2023, 03:38:03 pm by DavidAlfa »
Offline asupsp700
  • Country: ua
« Reply #3521 on: July 05, 2023, 03:59:23 pm »
It's a good news. So I'll be switching to 1.10.2!
Offline DavidAlfa
« Reply #3522 on: July 05, 2023, 04:29:21 pm »
v1.10.3 released.
I also added your JBC picture!  :-+
The following users thanked this post: ricktendo, dcore, asupsp700, ststefanov13
Offline asupsp700
  • Country: ua
« Reply #3523 on: July 05, 2023, 04:37:22 pm »
Offline asupsp700
  • Country: ua
« Reply #3524 on: July 06, 2023, 04:50:12 pm »
Everything went great! Now I can choose tips when changing ....
