there are two beeps per edge detection of WAKE input. Currently I have no buzzer. Are you sure it's that? It will beep when waking but also when reaching the temp.
So if you go to sleep and wake up quickly, both things will happen very closely in time.
How is successful / failed calibration determined?Basically, it checks that T450>T350>T250. And than none of the new calibrated values exceed the ADC range.
So for example if your T450 was ADC 3900 and you measured 300ºC.
The calibration (Not exactly done this way) would be something like: 3900/300*450 = 5850.
The max ADC value is 4095, so the calibration will fail.
Otherwise it could store a number higher than the ADC, that would push all the power into it, while never reaching the setpoint, making a T12 candle.
This was another security check added some weeks ago.
Also, if you are getting unstable readings, the calibration will likely fail.
(the temps are way off)That's the problem with so many tips and boards.
First, I set it a lot lower to avoid exactly that, then people complained that it was too cold on default calibration.
Then I put it normal, now they are getting candles
As you see, almost nobody post their calibration results.
That way I can't make a proper table for each board and set a default calibration.
increasing EMA filter factor 2 -> 3 helped a bit though.If it's unstable, increase the delay, not the EMA factor. The ema is designed to filter small spikes.
Also a bad power supply/noise will cause a lot of trouble.
Are the tips new? You know they do that for maybe 10 minutes, right?
Don't calibrate a new tip before lthe burn-in time!
The original Quicko firmware is indeed terrible!Terrrible is not enough. There are no words in the human language to describe it.
The standard calibration values for the Quicko almost made my tips glow,The Quicko board has adjustable gain, there's a pontentiometer in the board behind the display that can change the gain between 160 and 300.
You can guess what happens if the gain is too low.
Either set the gain higher or change the default T12 values than can be found in Core/Inc/settings.h
Lower the values by a 30% or so, and try again.
Found an SSD1309 2.42"Yeah they're basically the same thing with bigger pixels.
Not willing to pay 15$ for them just to see the temp
