Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 693524 times)
Offline DavidAlfa
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #1900 on: August 27, 2021, 08:07:44 pm »
No worries. Yep, still much cheaper than a $300 soldering station.
I've been thinking on adding languages for a long time.
While english is ok for most people, I know it's very different for russians and other slavic countries.
However, you can see yourselves the available space, everything is really tight.
I know nothing about these languages and their symbols, except that "Bomb" (бомба) is very similar to spanish "Bomba" :-DD
I would need to find a proper russian font that fits and looks good in the screen, which is not easy.
It's ok to add other languages too, there's plenty of space.
So, if you want translations, help a bit by seeking the menu labels/buttons/messages and finding something that would fit in there!
I think the fw is actually pretty finished, but I might give it a last push for a proper ending.
Offline wickated
  • Country: ru
« Reply #1901 on: August 27, 2021, 09:52:14 pm »
BTW so you know how these Chinese vendors work. They normally won't actually send you the unit directly. They send you an Amazon gift card or Paypal you the money to order off amazon so that way they get a sold item on amazon, they normally expect a review on amazon also.
my country is nearby china so ppl just write on ali/tao directly with starting words "send me free item_name"
i can make direct dictionary style translation, how can i make proper font? cuz we actually have weird symbols like Ф Э Ы Я Ю Щ  :-DD
im still too dumb to load even load a project in ide, not even compile it
so i renamed menuitmes with stlink direct fw editing  :palm:
stand bug still there since 8-04 ?
« Last Edit: August 27, 2021, 10:01:01 pm by wickated »
Offline ricktendoTopic starter
  • Country: hn
« Reply #1902 on: August 27, 2021, 10:46:42 pm »
Even if you did not have enough space, you could do what they do with IronOS and generate separate language bins.
What I think would be great is if they did a similar thing with this firmware as it did with IronOS (Ralim firmware,) it would be nice if a member of the forum developed a new open source controller board to better replace the KSGER chinese soldering stations (like the $25 Pinecil did to the $50 TS100)
Maybe something cool looking like this!
« Last Edit: August 27, 2021, 10:57:37 pm by ricktendo »
Offline DavidAlfa
« Reply #1903 on: August 27, 2021, 10:53:41 pm »
The stand bug was fixed some buils ago.
Manually building 10 bins for each model, 50 builds everytime? No way!
Just make the translations, and I'll do the rest.
Changing the font is a child's game. The problem is finding one that isn't too big, too small, too wide and doesn't look terrible when downscaled.
Offline wickated
  • Country: ru
« Reply #1904 on: August 27, 2021, 11:37:37 pm »
is it coded same as on symbol displays ?
Offline DavidAlfa
« Reply #1905 on: August 28, 2021, 03:57:36 am »
The font could be seen as pack of icons.
Each ASCII code number retrieves a different glyph and that's what it draws.
Don't worry about that, just help with the translation  :-+
Offline wickated
  • Country: ru
« Reply #1906 on: August 28, 2021, 12:21:28 pm »
looks cool
i just have to translate stringnmae in \gui\menu.c etc and zip them or add commentary lines or how?
Offline DavidAlfa
« Reply #1907 on: August 28, 2021, 12:52:27 pm »
But is that ok? Without russian symbols?
Modify the files from drivers/graphics/gui/screens/, once done Zip everything and send it to me.
« Last Edit: August 28, 2021, 12:54:17 pm by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #1908 on: August 28, 2021, 12:57:14 pm »
just a quick try. symbols are needed. im limited in screen width only ? (words in russian are much longer)
and big signs like NO IRON on main screen are text too ?
p.s. possibly confirm stand bug fixed. got some HUGE overshoot, tweaked PID a bit. imax 0,85 is overkill for jbc, it blasts 50c over settemp on liftoff. i got imax 0,4 for stable little_underload, 0,5 overshoot little
« Last Edit: August 28, 2021, 01:02:03 pm by wickated »
Offline DavidAlfa
« Reply #1909 on: August 28, 2021, 01:06:28 pm »
I think it was fixed. It's you who must test it and confirm it's no longer happening :-DD
I found a font that might do nice. As I said, you know the available space. If it won't fit, then it's better to leave it as it is...
For testing, type the settings screen options in russian (IRON, SYSTEM, DEBUG, EDIT TIPS, CALIBRATION, EXIT).
Offline wickated
  • Country: ru
« Reply #1910 on: August 28, 2021, 01:30:29 pm »
(ОБЩИЕ,СТАНЦИЯ,ОТЛАДКА,БАЗА ЖАЛ,КАЛИБРОВКА,ВЫХОД)
found some code example for arduino for u8g2 with good font, dunno if utf8 enable is also needed here
https://github.com/olikraus/u8g2/blob/master/tools/font/build/single_font_files/u8g2_font_unifont_t_cyrillic.c
« Last Edit: August 28, 2021, 01:36:01 pm by wickated »
Offline DavidAlfa
« Reply #1911 on: August 28, 2021, 01:39:56 pm »
Yes utf8 needs to be enabled (Already done on my tests)
Offline wickated
  • Country: ru
« Reply #1912 on: August 28, 2021, 01:43:48 pm »
very nice u have my cat, now feed him  :-DD
i counted 15 symbols in line with selector, 16 without, small symbols looks weirdm so CAPS FTW
« Last Edit: August 28, 2021, 01:45:46 pm by wickated »
Offline DavidAlfa
« Reply #1913 on: August 28, 2021, 01:47:06 pm »
The characters are not fixed width, so will vary.
This font seems ok for both. There are only few cyrillic fonts!
Offline wickated
  • Country: ru
« Reply #1914 on: August 28, 2021, 01:55:01 pm »
very good. so im running in translation 8)
sent in pm. tried to fit everywhere
« Last Edit: August 28, 2021, 06:35:20 pm by wickated »
Offline DavidAlfa
« Reply #1915 on: August 29, 2021, 01:53:52 am »
The fw layout is not designed to be randomly changed, everything is carefully placed, so using a different font causes slight cosmetic bugs.
There are very few fonts supporting cyrillic, so there isn't much I can do.
Still lots of text overlapping, need fixing by changing the labels to something shorter, or reducing the russian font size further.
I still need the translation for calibration screen error:
     .CAL_Error = "ERROR DETECTED!",
     .CAL_Aborting = "Aborting...",
Check the attached file  :-+
« Last Edit: August 29, 2021, 01:59:01 am by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #1916 on: August 29, 2021, 07:55:06 am »
nvm. errors were caused by overrun protection  |O
test fw dont work with tip/handle disconnected
everything else work good. need some fixes to avoid overlaps and better word meaning for SAVE OK buttons etc, some more CAPS for clear view and "strings" translation
« Last Edit: August 29, 2021, 09:51:20 am by wickated »
Offline AndyC
« Reply #1917 on: August 29, 2021, 08:52:14 am »
I translated v1.0 to Swedish earlier this year, so I made an attempt again with the new version. Seems to work well so far. Some tweaks had to be made of course, like adding 'ÅÄÖ' etc.
I added/replaced some caps on a 3.x board which had been acting weird previously. (Random wakeups)
The mod (like suggested earlier in the thread) got rid of some noise on the 3.3V, but the PSU noise still gets through. See attached photos.
Made a mini setup with a KSGER 2.1 + 3.1 controllers. Added audio jacks since I expect MP3 support soon :)
Easy to work with and portable.
And as you can see, the KSGER 3.1 is completely flatlining :)
Offline wickated
  • Country: ru
« Reply #1918 on: August 29, 2021, 09:42:21 am »
so u can flash only when powered wth psu? seems ok cuz i dont have any suitable ports in local shops for backplating.
Offline DavidAlfa
« Reply #1919 on: August 29, 2021, 11:36:22 am »
What errors are you talking about?
Is that a proper error reporting?
"Don't work"? No problem,  I'll fix the "no work" problem :palm:
Currently the big NO IRON text won't be displayed because there's no russian symbols, but all others, yes.
Else than that, it should be working normally.
Jokes aside, there a lot of blind people using the firmware, or at least they don't know how to read the instructions, asking the same things again and again, so the MP3 could be for voice guidance  :-DD.
If you modified the existing bdf fonts to add these characters, then why don't commit the changes?
For a few characters it's ok, but as it needs to be done by hand, it's extremely time consuming if you have to add a lot.
But that's what needs to be done here.
Currently I'm using a different font for russian, it would be much better to modify the current fonts instead.
But ain't just normal letters with accent marks...
Wickated, seems you'll have some work to do.
Time to start compiling and trying the translations,. it's very easy, It just takes a lot of trial to fit everything nicely ;).
Will post some guidelines later.
« Last Edit: August 29, 2021, 11:58:22 am by DavidAlfa »
Offline wickated
  • Country: ru
« Reply #1920 on: August 29, 2021, 12:20:13 pm »
sorry for that, ill make vid for that.
https://youtu.be/tVBiQWcIcTo
i think i can make project in ide with current guides. but abcolutely no clue how to conpile .elf in .bin
« Last Edit: August 29, 2021, 12:51:16 pm by wickated »
Offline AndyC
« Reply #1921 on: August 29, 2021, 12:42:56 pm »
Yes, but it was what I had.  It works ok though. Open to suggestions for proper SWD ports.
I don't even know what that means :) But of course I could share the modified files. I'll just zip'em if that's ok.
Offline ygi
« Reply #1922 on: August 29, 2021, 01:05:28 pm »
I realized something I'm kinda concerned about, so to speak. Since the controller remembers the last set t° after powering up, that means it stores it to flash every time it's changed, right? So wouldn't it be better if current set t° were simply stored in RAM and the default startup t° would be a user defined setting?
Admittedly, I have no idea how NAND durability is on those MCU but my guess is probably not that great. The thing is, I checked availability and price of STM32 yesterday and... it's scary. Now I look at my 1.5$ Chinese fake stlink from years ago like it's precious cause it has a "rare" 20K/128K F103 inside :palm:
Offline wickated
  • Country: ru
« Reply #1923 on: August 29, 2021, 01:56:18 pm »
settnigs are written to flash once per 5sec. in original fw with eeprom they are saved every encoder tick. if u really worrie about lifecycles u can just set longer timeout for write operations
Offline dark_hawk
« Reply #1924 on: August 29, 2021, 02:47:10 pm »
I've just tried the new version and things seem to be settling down for good.
I have a few good tips and 2 bad ones, the good tips seem to work fine using the default PID values with no change to system settings.
Good tip:
Recovering from a load:
Recovering from a bigger load:
Now for the bad tips, which used to flucuate like crazy in the original firmware:
Using the default PID values:
Reducing the KP, Ki and Kd:
PID= 30 20 10 (If I remember correctly) Starting up:
Stabilizing:
Problem is recovering from a load takes a lot of time and cycles:
So I decreased Kp and Ki further, increased Kd a little, here is a recovering from load PID (22, 10, 15):
I'm very satisfied with the current results, but if there is room for improvement specifically in the load handling part of things please point me in that direction.
Thanks david.
