Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 954121 times)
Offline marck120
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #4275 on: October 23, 2024, 12:21:50 am »
I wanted to show you this video, it seemed interesting to me, the original power supply of the ksger has been replaced with a toroidal transformer, the rectifier bridge has been added, a capacitor to filter the current and a second optional switch.
Offline DavidAlfa
« Reply #4276 on: October 23, 2024, 03:36:26 am »
Check soldering...
Offline nokin
  • Country: vn
« Reply #4277 on: October 23, 2024, 07:22:33 am »
How are you wiring everything?
Hi, can you share me how to wire them correctly ? Thanks !  ;D
Offline moffet
« Reply #4278 on: October 23, 2024, 09:39:18 am »
I ordered new 1.3" OLED screen from Aliexpress.
4pin, i2c.
Offline nokin
  • Country: vn
« Reply #4279 on: October 23, 2024, 11:24:54 am »
I've destroyed c210 tip today, by setting C245 profile while using C210 tip. Heater's resistance is Mega ohms now.
I just want to test behaviour of control when switching handles without choosing corrected profile.
The c210 was ok before (except sleep function)
Offline marck120
« Reply #4280 on: October 25, 2024, 12:37:04 am »
Sorry, on github it says that the 952 is not compatible:
T12-951, T12-952, T12-956, T12-959 use STC MCU, not supported by this firmware.
On the Aliexpress description however they say that the 952 is an STM32, why ?
https://it.aliexpress.com/item/32803295956.html
Offline DavidAlfa
« Reply #4281 on: October 25, 2024, 08:48:38 am »
Checking some pictures in the feedback, it's clearly STC.
The following users thanked this post: marck120
Offline marck120
« Reply #4282 on: October 25, 2024, 10:53:16 am »
Thank you, from the photos how can you identify if it is an STM32 ?
I was fooled by the photo of a user on the Aliexpress review, on the chip I had read STM32:
Offline DavidAlfa
« Reply #4283 on: October 25, 2024, 11:40:25 am »
That's a new version, unknown to me.
Just ask pictures to the seller.
Online elektryk
« Reply #4284 on: October 25, 2024, 11:41:47 am »
As stated earlier F030 is not compatible with this CFW.
Offline DavidAlfa
« Reply #4285 on: October 25, 2024, 01:25:04 pm »
Nope, no way the FW will fit in 32KB flash!
Offline marck120
« Reply #4286 on: October 25, 2024, 08:09:57 pm »
Thank you very much, besides the photo of the chip I thought there was another way to identify if a controller is STM32
Offline moffet
« Reply #4287 on: October 28, 2024, 04:15:56 pm »
Check soldering...
I solved the problem with the screen. Now I'm trying to calibrate everything using T12 tip (chinese one). The handle has an NTC build in, and it is enabled in the menu. The firmware is showing accurate ambient temperature in the upper right corner.
I started in Calibration->Settings. Set the Zero set (when the tip was cold), Cal 250°C, and stuck at 400°C.
Before the tip reaches 400°C (probably around 360°), the firmware aborts the operation with the ERROR DETECTED message.
I'm measuring the tip with a multimeter with a thermocouple.
Currently I have the following settings:
Zero set      612
Cal 250°C    2360
Cal 400°C    3960
Maybe the voltage offset of the amplifier is too big. It is unknown 621K amplifier.
« Last Edit: October 28, 2024, 06:11:44 pm by moffet »
Offline DavidAlfa
« Reply #4288 on: October 28, 2024, 07:13:15 pm »
Cal400 is too high, should be way lower than 4000 (4095 is the max. the stm32 can read), usually gets around 3000.
Is that an original board?
The gain seems too high (Normally the op-amp has 1K/249K resistors).
Or maybe the amplifier is bad, or you measured cal400 wrong.
Offline moffet
« Reply #4289 on: October 29, 2024, 05:09:48 am »
This is the original board.
I see 39D (249kΩ) and 1kΩ resistors around the amplifier.
Offline ovis
  • Country: lt
« Reply #4290 on: October 29, 2024, 08:32:53 am »
What would be the disadvantages of buying unit with segmented LED display (mm32) over the OLED (stm32). It has sleep, shutdown modes, temperature calibration and I like a simple display.
https://www.aliexpress.com/item/1005007597204295.html
Online elektryk
« Reply #4291 on: October 29, 2024, 10:35:22 am »
There is no option to individually calibrate the tip or switch profiles, which can sometimes be useful, not to mention other interesting settings.
Offline sst311212
  • Country: tw
« Reply #4292 on: October 29, 2024, 04:20:37 pm »
Zero set      612
Cal 250°C    2360
Cal 400°C    3960
Your ZeroSet is too high, you may need change op-amp.
My ZeroSet is near 30 at 30°C with modded ksger gx board. (AD8605)
The following users thanked this post: moffet
Offline moffet
« Reply #4293 on: October 30, 2024, 05:43:33 pm »
I just replaced the amplifier with the Texas Instruments OPA336NA and now Zero set is 11 insted of 612.
So if you have 621K amplifier, replace it.
The following users thanked this post: DavidAlfa
Offline ladimir
  • Country: ua
« Reply #4294 on: November 29, 2024, 08:38:40 pm »
... Assuming I've traced the schematic properly (attached) and interpreted it properly, it looks like docking the iron on the stand causes pin PD1 to be pulled low.
Please consider some of my clarifications regarding the scheme
1. Usually in circuits smoothing capacitors have a nominal value 100nF (C6, C14, С15, C16)
2. U1 is missing contacts number 35 and 44.
3. U4 - TP1431A has a different pin numbering.
Offline porlock
« Reply #4295 on: December 21, 2024, 08:37:33 pm »
It's is possible to make latest Ksger board works for t12 and C245 :-// ? of course after switching profile in @deividAlfa firmware.
2467293-0
I did some pin out analysis, and this is what i figured out .. any chance that this will work ?
2467285-1
I refereed to this page:
https://eevblog.com/forum/projects/jbc-handle-cartridge-data/
I also did some measurements.
C1-C2 - 6 ohm
C1-C3 - 3.5 ohm
C2-C2 - 6 ohm
Thermocouple has much less resistance than heater, so how to prevent from large current flow over it ?
C1 should be connected to high impedance input, that seems not be the case.. and there is no pin for it on any Ksger boards
In this thread i also find this schematic that its quite similar to my, but in this ground seems to be floating right ? so .. JBC tips are not grounded ?
2467289-2
Hoever i saw people did that modification successfully.. can someone point me where i did mistake ?
« Last Edit: December 21, 2024, 08:40:23 pm by porlock »
Offline DavidAlfa
« Reply #4296 on: December 21, 2024, 08:39:26 pm »
Please use the search button, this showed up quickly:
« Last Edit: December 21, 2024, 08:41:12 pm by DavidAlfa »
Offline porlock
« Reply #4297 on: December 21, 2024, 08:55:46 pm »
OK, i got it,  so J will be hi impedance i guess.. so are you sure it should be connected to C3 not to C1 ?
« Last Edit: December 21, 2024, 09:40:00 pm by porlock »
Offline porlock
« Reply #4298 on: December 21, 2024, 09:42:49 pm »
sorry i get confused :D everything is correct.
Offline oleg401169
  • Country: ua
« Reply #4299 on: December 31, 2024, 01:38:25 pm »
Does anyone have cubeide version 1.12.1? I can't download this version anywhere.
