I've read a couple user complaints about Thermaltronics tip wear. Metcal are supposed to have a lifetime warranty. Although, I'm not sure exactly what it covers. Maybe only manufacturing defects?
I don't think the Quick induction iron is compatible with Metcal whatsoever. It appears to be some hybrid design with induction and thermocouple since it's adjustable. Not sure what advantage it would have over any other design with a thermocouple?
As I understand it, the induction heating is more responsive. You're heating only the low thermal resistance core which is directly connected to the tip rather than the heating element and everything surrounding it. Certainly I would say the Metcal GT120 soldering station which uses induction + thermocouple seems a lot more responsive than a standard resistive heating element.
Mike said he's been using Thermaltronics tips without any notable difference in quality.
Metcal cartridge warranty is that the heater will outlast the tip plating. Generally that means if the heater fails, it will be replaced, though I've still got cartridges 10+ years old.
