Sidetrack
6 for 600°F, 7 for 700°F, 8 for 800°F.
Misleading marketing? The Metcal series 6 is described as 600F, but the set point is actually around 650. The 7 is around 750.
Thermaltronics follows this tradition. For instance they list the temp of their "600F tips" only in Celcius (lol) : 325-358C. If you do the conversion, this is 617F-676F. If you split the difference, it is 647F.
If you didn't bother to measure the temp of your tip or do a simple conversion, you might think the Metcal/Thermaltronics tips are punching beyond their weight class even if they're not.
To put it in perpective, the average set temp of Metcal's lowest temp line is not much lower than my "overdrive" setting (350C/662F) on my 888. I only use it for soldering to heavy ground planes and battery terminals. I don't remember the last time I used it; it's been a long while. Over 90% of my soldering is done at 315C, which converts to 599F. That's an actual "600F tip."
OP, the 888 is fine for prototypes. Plenty of power and good tips. Cartridge style irons are better for production line which has high heatsinking continuous demand. They can pump out more watts without the handle "catching on fire." If the demanding joints are not a bang-em-out, one after the other for 10-20 minutes straight, I don't think you get a lot of benefit for the $$ over a US priced 888 regarding the iron part. I have no experience with tweezers, though. I never found a reason to buy them other than as toys. I had a set for a different station. Between a good iron and hot air, I never found any purpose for the tweezers which saved any time or effort.
