Thank you for the number. 10X/18mm would be considered wide field for eyepieces that fit older 23.2mm tubes, like those on this student dissecting microscope from the 1980s:
I wonder if those 30.5mm eyepieces are really 23.2mm plus spacers.
The Swift/Amscope has 2.4X the working distance of the dissecting microscope, but at the cost of that much less optical resolution. Using stronger than 20~25X eyepieces will likely produce empty magnification.
