Author Topic: WLX-936D Solder Station schematic  (Read 4739 times)
Offline jdev99Topic starter
« on: July 06, 2017, 11:06:16 pm »
I bought one of these in 2015 for £28 and was quite happy with it until recently.
It started giving all weird problems, temperature fluctuating, flashing display, dead display etc.
So I decided to take it apart to see if I can find the problem and maybe fix it.
While it was apart, I decided to redraw the schematic (as accurate as I can)
To my surprise it actually uses an Atmega8a-AU.
This is the result:  (See attachments)
In the end I decided just to "upgrade" it to this :
https://www.hackster.io/sfrwmaker/soldering-iron-controller-for-hakko-907-v-2-fc75d7
« Last Edit: July 10, 2017, 11:37:10 pm by jdev99 »
Offline Nusa
Re: WLX-936D Solder Station schematic
« Reply #1 on: July 06, 2017, 11:27:51 pm »
Gotta love how whoever assembled that completely ignored the strain relief holes for 9V and 24V wires.
Offline stj
« Reply #2 on: July 07, 2017, 10:31:48 am »
you should look at these projects if you really want to use that shit iron.
the original
https://debugginglab.wordpress.com/2014/10/30/soldering-station/
the improved version.
https://github.com/manolena/DIY-SMD-Soldering-Station
