Author Topic: Tektronix 2225 Probe Adjust  (Read 2965 times)
Offline MatTopic starter
« on: September 24, 2011, 01:34:58 am »
Hi!
I've got a Tektronix 2225 and something seems a little odd :
The probe adjust signal is a negative pulse square wave (from 0 to -0.5 V).
Can anyone tell me if this is normal? In his review, Dave only tests the probe adjust on AC coupling...
Thanks,
Greetings,
Mat
Offline Psi
Re: Tektronix 2225 Probe Adjust
« Reply #1 on: September 24, 2011, 01:49:48 am »
Have you checked if the channel has invert enabled?
« Reply #2 on: September 24, 2011, 09:58:14 am »
I remember that this happened on both channels and there is no invert on channel 1.
Offline TheEENerd
« Reply #3 on: September 25, 2011, 07:28:12 pm »
Don't worry, my 2225 is doing the same.
« Reply #4 on: September 25, 2011, 10:41:50 pm »
OK thanks!! One less thing to fix on this scope!
I am waiting for a power switch (only the black plastic rod going from the front to the mains input board on the back) and some missing case screws.
When I receive them, I'll post some pics!
Because you know what Dave says on the EEVblog : Don't turn it on, take it apart!!!
TheEENerd : Thanks again!
M.
Offline TheEENerd
« Reply #5 on: September 26, 2011, 07:00:30 am »
You r welcome. I picked up my 2225 locally here in Sydney. Got it calibrated, and now waiting for some new accessories.
