I have 2 young boys who go in the shop with me. I can't have a power supply with 46 volts AC on the chassis. This is a shock hazard that could hurt someone and is not due to torroidal transformer start-up surge current.
If anyone has any suggestions based on my measurements above on where to look to home in on the problem, I'd appreciate it.
Thanks much
JimmyK
Firstly I would suggest that you have a RCD installed in your workshop. If you have and it is working correctly (when did you last test it ?) you should be protected from electric shock hazards.
When you disconnect the ground from the power supply, the output voltage on the secondary will float. Measuring between utility ground and the PSU ground will show a reading, but is usually high impedance unless there is a ground fault, and that is what the RCD is there to protect you against.
To test, you could connect a 1K resistor between the utility ground and PSU chassis ground. If you still measure 46V you have a fault. I would guess the voltage will drop significantly close to zero.
Once you have established that there is no ground fault, you can proceed to check the secondary of the transformer.
Does the PSU have any secondary fuses that you can remove ?
If not, unsolder the secondary windings, tape the ends, insert a grounded utility lead and see if the fuse still blows. If it does you have identified a transformer fault or an incorrectly sized fuse.
Is your fuse antisurge or fast blow ?
Most torroids have huge input surge and require antisurge fusing.
If the fuse doesn't blow, it is highly likely that the fault lies with the electronics.
