Apparently Thermaltronics was started by some former Metcal people when the patent ran out. The tips are compatible with Metcal. $400 is certainly a great price for what is basically an MX-5000 clone
• MX5000 and the TMT-9000S are both 13.56Mhz RF power supplies and spare parts and tips are compatible with each other• Both systems have several years warranties• Both systems are dual switchable systems• Both systems have the capabilities to add through hole desoldering and surface mount tweezers handpiecesHaving used and supplied both products over the years, the MX5000 is a higher power system than the TMT-9000S. Although, this extra power is unnoticed when using fine tips for surface mount because the tips are so fine they are limited to the amount of power they draw.For very heavy applications when used with very large chisel tips, the MX5000 will have the ability to draw more power than the TMT-9000S. In saying that, I have not found an application yet, were the extra power that the MX5000 possesses has been necessary.As you mentioned the MX-5000’s are lot more expensive and I think an over kill for 95% of most applications. With the MX5000’s price ranging from $750.00 up to $950.00 you are paying extra for a brand name and this then puts the unit out of most people price range.With 650+ TMT-9000S sold in Australia alone over the past 12 months, the TMT-9000S is priced very well for the performance and options that it provides and is fast becoming the technicians first choice for benchtop soldering equipment.
