Author Topic: Toroid ISB-100W Isolation Transformer  (Read 3880 times)
Offline insurgent
« on: May 23, 2011, 05:54:22 am »
I just purchased one of these on Ebay. It's a 1000VA, medical grade, 9 outlet, 120/240 V for about $85USD + $25USD shipping. These things list for $560 new so it seemed worth a shot!
Nice aluminum enclosure, fairly small (approx 4 in tall, 8 in wide, 12 in long) and weighs in at 22.6 lbs (apologies in advance to my European brethren for the archaic measurement units). Held together with Torx screws and I didn't have an exact match so the actual screws are probably 1 size greater than these: Sides 8 x T15 and top 1 x T27.
Good thing I used the meter on it first to test that all the outlets were working: The unit was set to 240V output!
Attached are a few pictures for your entertainment. If you are looking for one, the guy has 5 left, just search EBay.
Offline Zero999
  • 0999
Re: Toroid ISB-100W Isolation Transformer
« Reply #1 on: May 23, 2011, 04:25:17 pm »
It looks like you've got a good deal.
The output is floating which is exactly what's required for working on a test bench.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: May 24, 2011, 12:26:56 pm »
Thanks for the headsup, I could use of these.
Best Wishes,
 Saturation
Offline sacherjj
« Reply #3 on: May 24, 2011, 02:15:45 pm »
For those wanting one, this is the link: http://shop.ebay.com/i.html?_nkw=isolation+transformer&_sacat=0&_odkw=1000VA+isolation&_osacat=0&_trksid=p3286.c0.m270.l1313#http://cgi.ebay.com/Toroid-ISB-100W-Isolation-Transformer-115-230V-/220786389040?pt=LH_DefaultDomain_0&hash=item3367e4f030&vil=1
And he only has 4 left, now.  :)
Thanks for the heads up.  I've needed on of these and I didn't want to pay much more than this, but didn't expect to get 1000VA capability for the money.
I knew I bought a bunch of those AC interface pig tails from something a couple years ago...
« Last Edit: May 24, 2011, 02:18:21 pm by sacherjj »
