I hate non-answers to questions posted on blogs, but maybe my experience is slightly relevant. I like the idea of a torque measuring screwdriver and have often considered buying one. For home use, there are a lot less expensive torque-indicating drivers available, and modern digital versions are very attractive. I just haven't pulled the trigger yet. I do have experience with torque wrenches and currently have 5 dating over generations to the 1960's. My oldest are Craftsman, made in USA, and torque bar indicating.
Torque limited v. torque indicating: I worked with a considerably older and experienced AI mechanic in the 70's and 80's on civilian aircraft. He would not allow a click-type torque limiting wrench on critical components, which included spark plugs. However, there is no argument that clicker wrenches are easier to use particularly when working in limited space and difficult visibility. That is what I usually use today on my car and implements. I always use torque indicating on spark plugs and other things screwed into aluminum heads.
With respect to my hobby electronics and home, the biggest problem is with coarse threaded, "thread forming" screws in soft materials like plastic, aluminum, and sheet metal. The risk of cross threading and destroying existing threads is high. Do that a few times, and there are no more threads. The best solution is to turn the fastener backwards until you just feel a little click or give, then proceed to turn in the correct direction, which is usually clockwise. That first turn is critical, and if there is more than the usual low resistance, repeat the procedure to find the correct thread start. A dedicated screwdriver (i.e., one without removable bits) is best for feel, but not required. Final torque is up to you. For home use, snug or just a little beyond it is all I do. In sheet metal, too loose a fastener can allow the screw to get slightly cross-threaded and needs to be avoided.
