Author Topic: transfromer information  (Read 2464 times)
Offline kjn4685Topic starter
« on: November 04, 2014, 05:01:36 am »
I am trying to build a transformer tester I use a lot of transformers need to be able to test each pin at a time If any body have any ideas. I would appreciate any help I can get
Offline anachrocomputer
Re: transfromer information
« Reply #1 on: November 04, 2014, 02:03:07 pm »
What type of transformers do you want to test? Mains power transformers? Audio transformers? Pulse transformers? And roughly what voltage and current ratings do these transformers have? We need a bit more information before we can give you a good answer.
« Reply #2 on: November 04, 2014, 10:53:42 pm »
They are power transformers and audio. The voltages ranges from 12vac to 120vac. I am testing for shorts and resistance.
« Reply #3 on: November 05, 2014, 07:38:55 pm »
Easiest is a regular transformer with a secondary of 12VAC and 3VAC, with a series incandescent lamp of 12V 0.1A and 3V 0.2A to limit current. this is connected to any winding and then you measure the assorted outputs to get the ratios using an AC voltmeter. The lamps are there to do current limiting in case there is a shorted winding.
« Reply #4 on: November 05, 2014, 07:49:37 pm »
Thank you very much.
