I absolutely can recommend the JBC station, since i first used a JBC iron i couldnt go back to other irons.
JBC is using active tips where the heating element is in the tip, at my opinion its a huge difference to "normal" irons like the ersa.
I used the Weller WX line a lot, they are very good but i like the JBC more.
I am using my JBC station for a Year now and all tips are still fine with average usage (2-10h/week) and the recommended handling.
The tips are available at conrad or welectron for average costs (20-30€).
At first i used the T245 for everything from pure copper plates down to 0201 SMD components.
Two month ago i purchased the T210 handle and i love it for SMD soldering, it can be used with the same station as the T245.
For the beginning i would recommend the following tips, i like to use chisel tips:
-C245-907 for Heavy duty and THT components
-C245-944 for bigger SMD components 1206-0603
-C245-906 for smaller things 0402..
In germany we have a saying: as big as possible, as small as necessary
Thats perfect for soldering tips.
I would take the JBC maybe its a little bit more expensive but you wont regret it at all.
I have to say, since im using JBC products im a little JBC fanboy, but i think thats not for no reason
I hope that helps you a little bit.
Edit: my company is using JBC for over 10 years now and never had problems with their products.
And they over a free 30 Days test of their equipment on their website
https://www.jbctools.com/ask-demo-pro933.html, maybe you just test one of their stations.
