Author Topic: Warning: Fake 100A Fotek Solid State Relays  (Read 19242 times)
Offline gnifTopic starter
  • Views and opinions are my own
    • AMD
« on: August 21, 2019, 09:55:33 am »
Ordered a couple of Fotek solid state relays from eBay marked as being able to handle 100A (SSR-100 DD), I bought two figuring I would tear one down and verify they are indeed 100A modules before putting it into use. Here are the results.
816213-0
Yes, that's a 2SC4110, a 25A transistor.
Buyer beware!
« Last Edit: August 21, 2019, 01:26:55 pm by gnif »
The following users thanked this post: bdlow
Online Ian.M
Re: Warning: Don't buy FOTEK Solid State Relays
« Reply #1 on: August 21, 2019, 10:24:02 am »
So its a fake, which isn't surprising on EBAY.  It looks like the whole SSR-nnDD product range uses the same housing, so it *MAY* simply be a remarked SSR-05DD or SSR-10DD, which would be consistent with the 60V voltage rating.  All the higher power SSRs in the range are rated for 120V DC.  Its also interesting to note that I couldn't find any reference to a SSR-100DD model on the Fotek website
http://www.fotek.com.tw/pdf/SSR-DD.pdf
The following users thanked this post: gnif
Offline wilfred
« Reply #2 on: August 21, 2019, 12:32:01 pm »
No link to the Ebay listing. Come on. Give us a fighting chance to make our own minds up.
    • AMD
« Reply #3 on: August 21, 2019, 01:24:49 pm »
Whoops, sure: https://www.ebay.com.au/itm/133095376627
Edit: Just noticed that the label is completely different on the unit, so perhaps not Fotek's fault, but a fake/rebadged unit. I have re-titled the thread in accordance with this.
« Last Edit: August 21, 2019, 01:27:26 pm by gnif »
Offline wilfred
Re: Warning: Fake 100A Fotek Solid State Relays
« Reply #4 on: August 21, 2019, 02:24:47 pm »
Good one Gnif. Big Clive did a teardown of one of these things. @5:00 he notes the triac is not sufficient for the stated current.
Offline thm_w
  • Non-expert
« Reply #5 on: August 23, 2019, 12:52:51 am »
That wasn't overly cheap too, $13 each.
Here are some genuine 40A for $6: https://lcsc.com/product-detail/Relays_CDG1-1DA-40A_C108612.html
There are lots of alix sellers but the reviews are not really useful, just lowish loads reported, none taken apart, so not clear if its genuine:
https://www.aliexpress.com/item/32845269143.html (one review saying it blew up but its not clear if it had appropriate heatsinking).
https://www.aliexpress.com/item/32865807659.html
https://www.aliexpress.com/item/32906876577.html
https://www.aliexpress.com/item/32842313085.html
Maybe its possible to measure the on resistance of output and get an idea of the internal FET?
Also in another thread it was mentioned the clearance of the fake was terrible: https://www.eevblog.com/forum/beginners/dc-ssr-wont-turn-off/
Offline james_s
« Reply #6 on: August 23, 2019, 03:09:09 am »
This has been common knowledge for years. I'd expect a genuine 100A SSR to cost at least $50. Ebay is full of fake garbage that is nothing more than a commodity triac screwed to a piece of aluminum with a basic optocoupler circuit.
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: August 23, 2019, 04:03:34 am »
I'm surprised they even bothered with the conformal coating.
Offline vlady_2009
« Reply #8 on: November 07, 2019, 02:19:59 am »
Since these fakes so cheap (can be ~$4) thought I would check them out in any case.
For anything "serious" obviously not worth the risk, but if used highly derated, potentially useful, especially when "her in doors" frowns upon every dollar spent on "frivolous hobbies"  ::) .
I use a notional 40A SSR for a 10A load (a DIY steam generator for essential oil extraction based on a 2400W element) - the teardown of the actual SSR showed a 24A triac used - and working OK so far.
Here is summary of results of the testing for any interested.
www . youtube . com/watch?v=rgW8L2LaAlU
Offline Ivanko1
« Reply #9 on: March 22, 2021, 10:47:07 pm »
I ordered SSR-60 DA on aliexpress, and LED light bolb still glowing (faded) after regulated voltage disconnected. Is it concidered as a fake and money can be refund?
Online Ian.M
« Reply #10 on: March 22, 2021, 11:02:59 pm »
According to the Fotek SSR-xxDA series datasheet, the max. off state leakage current is 5mA, which is more than enough to light a LED bulb.
The following users thanked this post: WattsThat
Offline james_s
« Reply #11 on: March 23, 2021, 02:26:11 am »
Look on the back and see if you can see the screw hole where the TO-220 triac is attached. Genuine will not have this.
Offline Ivanko1
« Reply #12 on: March 23, 2021, 08:31:22 am »
It have some
Offline james_s
« Reply #13 on: March 23, 2021, 05:30:31 pm »
It's very dark in those photos but that looks like there's a screw to me. If you paid less than about $50 for a 100A SSR it's fake. You could also try putting it on a heatsink and put perhaps a 30-50A load on it, it will probably fail almost instantly and then you know it's fake.
Offline Ivanko1
« Reply #14 on: March 24, 2021, 09:54:16 am »
Yes it have screw hole. I pay $10 for two SSR 60DA on aliexpress. I need it for REX-C100 and <1000W load on 220V.
Offline james_s
« Reply #15 on: March 25, 2021, 12:13:24 am »
If they are that cheap they are fake, period. Good for around 10 Amps or so typically, regardless of what the label says. Good quality name brand SSRs are much more expensive.
Online coppercone2
  • √Y√... 📎
« Reply #16 on: March 25, 2021, 03:17:25 am »
I recommend getting panasonic brand on digikey for heat related projects (SMD oven). Yes its like $50 but you can easily fry 4x that on a PCB if it fails short during a reflow and you get tired of watching it. I just don't trust the cheap ones.
Offline floobydust
« Reply #17 on: March 25, 2021, 05:08:13 am »
Everyone, don't forget a (triac) SSR dissipates about 1W per A.
They aren't really practical above say 60A because the required heatsink+fan is huge and thermal resistance of the SSR and mounting hardware is a problem. This is when people go with (or add) a mechanical contactor.
A 60A SSR will dissipate 60W and buying higher current-rated say 100A SSR doesn't mean it runs any cooler.
Crydom are the best because they mount the triac die right on the thermal slab (patent) for very low thermal resistance. But really expensive now.
Offline BreakingOhmsLaw
  • Certified solder fume addict
« Reply #18 on: March 26, 2021, 09:25:22 pm »
It could be even worse. The manufacturer of that fake SSR will take little care where they source their components. If that 12A Triac is actually a relabelled part itself with even less true rating than that, you might end up with a 6A Triac in a "40 A" SSR.
« Last Edit: March 26, 2021, 09:38:25 pm by BreakingOhmsLaw »
Offline GamingUnleashed
« Reply #19 on: July 13, 2021, 07:28:55 am »
well I just got stung with a box of 100 of these fakes
aliexpress will not do anything because I can not prove what a real one looks like ... which I know is impossible because their are no real 100A ...  to compare with
was needing ~40A to control DC heaters for the aquaponic setup and they blew ~ 30A with huge heat sinks installed , opening them up found turtle SSR 10DD PCB
can someone ID this part? or should I open up another to see if I can read the other side
opened up a few more and got one that is pretty readable
« Last Edit: July 13, 2021, 07:55:56 am by GamingUnleashed »
The following users thanked this post: darronb
Offline darronb
« Reply #20 on: July 13, 2021, 09:18:46 pm »
Here's what I received today, from an eBay order.
They were supposed to be 40A, and disassembly revealed a 24A Triac (MARKED AS SUCH, anyway...).
The last photo is from the eBay listing. As you can see, the photo shows it as a "Fotek", as per usual for these fakes.
But the total crap I received didn't even bother to say Fotek, instead being marked as FQFER, as far as I can tell (I pronounce this in my head as Fuk Fur).
At least they had the honesty to show "Made in China" on the label, rather than the former practice of claiming to be made in Taiwan.
Darron in Golconda, Nevada, USA
« Last Edit: July 13, 2021, 09:32:05 pm by darronb »
Offline thm_w
  • Non-expert
« Reply #21 on: July 13, 2021, 10:22:02 pm »
You'll have to peel that black stuff off to see the part number at the top.
I don't know why you'd buy 100pc of these without verifying the seller first? Even then, running 30A through them, I'd be super cautious about using these no name clones.. and no way in hell for any business use.
« Last Edit: July 13, 2021, 10:24:35 pm by thm_w »
Offline james_s
« Reply #22 on: July 15, 2021, 01:01:31 am »
I wouldn't trust those things to carry 10 amps. I'd say it's more likely than not that triac is fake too and nowhere near the 24A the number on it would imply. To at least some degree you get what you pay for. If it costs 1/10th what something from a reputable supplier costs then it's not going to be very good. There is some premium for the name with something like Crydom but it's nowhere near the price difference between a genuine one and these bottom of the barrel knockoffs.
« Reply #23 on: July 22, 2021, 08:23:58 am »
because it was from a factory with positive reviews .. however it seems aliexpress blocks all Negative reviews being sent ...  or at least I was unable to send anything that was not 100% positive
then the seller said the heatsinks I ordered (the only size I could even find listed) were only for up to 20A  while fan cooled
Offline james_s
« Reply #24 on: July 24, 2021, 05:22:10 am »
Well, write it off as education. I wouldn't trust any reviews that are 100% positive, even a good product will have a few mediocre and negative reviews. I would take even legit reviews with a grain of salt, a non-expert who buys a few cheap SSRs and uses them to control some light bulbs or other loads that draw a few amps and it works will likely leave a positive review.
