Hardware.fr periodically publishes data about failure rate, returns, warranty stuff using information received from - if i remember correctly - one of the largest seller of pc components in France ... here's some links:
1.
Dossier: Les taux de retour des composants (13) - 9 Novembre 2015
2.
Dossier: Les taux de retour des composants (12) - 19 Mai 2015
3.
Dossier: Les taux de retour des composants (11) - 6 Novembre 2014
Search for "Les taux de retour des composants" on the website for 10 older articles.
Here's some statistics from the newest article :
my personal comment :
1. note that HGST seems to be worse than Seagate but then if you look below there seems to be no particular HGST drive that has a higher percentage of failure, unlike some WD or Seagate series that pop out.
2. note that it's drives that came as returns in a six month interval after purchase, drives that were returned sooner are no here. As far as I know (and backed up by
google's research (see 3.3) , a lot of drives suffer of premature death, as in they die in the first couple of months or so.
3. I'm also losing the italics (which means that drive was sold in less than 200 pcs, if you're really interested visit the website (they deserve some money from advertising).
-- all stuff below from the article on the website
Return rates reported relate to parts sold between 1 October 2014 and 1 April 2015 for returns created before October 2015, 6 months to 1 year of operation. [..]
The statistics by make are based on a minimum sample of 500 units sold, by those models on a minimum sample of 100 units sold. When the sample is lower than 200 parts, the designation is in italics. [..]
- Seagate 0.60% (against 0.68%)
- HGST 0.81% (against 1.16%)
- Western 0.90% (against 1.09%)
- Toshiba 0.96% (against 1.34%)
The rates are falling, but Seagate maintains the lead. It should be noted that unlike other 3, Toshiba's return is necessarily made through the dealer.
For the fourth consecutive period, there is no disk with a return rate of over 5% down. Otherwise here are less reliable 5, with 2 cases of sales sales
are in the low range (100-200 rooms):
- 4.90% Toshiba 3TB DT01ACA300
- 2.86% 4 TB WD RE WD4000FYYZ
- 2.33% WD Blue 250GB WD2500AAKX
- 2.23% WD Black 4 TB WD4003FZEX
- 2.20% 750 GB WD Red WD7500BFCX
Server records obtained by capacity 3.5 "for discs sold more than 100 copies (italics 100-200 Sales):
2 TB:
- 1.69% Toshiba DT01ACA200
- 1.50% WD Black WD2003FZEX
- 1.41% WD If WD2000F9YZ
- 1.06% WD Purple WD20PURX
- 0.97% Seagate Pipeline HD ST2000VM003
- 0.94% Seagate Desktop SSHD ST2000DX001
- 0.68% WD Green WD20EZRX
- 0.65% Seagate NAS ST2000VN000
- 0.63% Seagate Barracuda 7200.14 ST2000DM001
- 0.59% WD Red Pro WD2001FFSX
- 0.44% WD Red WD20EFRX
- 0.41% WD RE WD2000FYYZ
- 0.24% Seagate Surveillance ST2000VX000
- 0.00% Seagate Enterprise Capacity ST2000NM0033
- 0.00% Toshiba PA4292E-1HL0
3 TB:
- 4.90% Toshiba DT01ACA300
- 1.94% WD If WD3000F9YZ
- 1.60% WD Green WD30EZRX
- 1.31% Seagate Barracuda 7200.14 ST3000DM001
- 1.25% Toshiba PA4293E-1HN0
- 1.23% WD Red WD30EFRX
- 1.23% Seagate NAS ST3000VN000
- 1.16% WD Red Pro WD3001FFSX
- 0.94% Seagate Surveillance ST3000VX000
- 0.71% Black WD WD3003FZEX
4 TB:
- 2.86% WD Re WD4000FYYZ
- 2.23% Black WD WD4003FZEX
- 1.53% WD Green WD40EZRX
- 1.40% WD Red WD40EFRX
- 1.32% Seagate Desktop SSHD ST4000DX001
- Seagate Constellation ES 0.82% ST4000NM0033
- 0.71% Seagate Desktop HDD.15 ST4000DM000
- 0.47% Seagate NAS HDD ST4000VN000
- HGST Deskstar 7K4000 0.00% H3IK40003272SE
- 0.00% 0S03665 HGST Deskstar NAS
5/6 TB:
- 1.47% WD Red WD60EFRX
- 0.41% WD Green WD60EZRX
- 0.00% WD Red WD50EFRX
