Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
MILL-STD-2000 difference ? Weller WXMP vs WXMP MS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MILL-STD-2000 difference ? Weller WXMP vs WXMP MS (Read 3277 times)
ErnieEngineer
Contributor
on:
December 20, 2017, 07:40:15 pm »
After a lot of poking around it looks like there is two versions of a soldering iron that appear to be practically identical. The version with the trailing “MS” adheres to some military standard and costs more.
Is there *really* a difference, or are they just charging more because govt customers will pay more?
Sure they are both fine, but this has me curious if anyone knows the truth.
Thanks!
See :
http://www.testequipmentdepot.com/weller/pdf/wxmpmsset_data.pdf
(MILL version)
http://www.testequipmentdepot.com/weller/soldering/soldering-iron-sets/wx-micro-solder-iron-12v-55w-200-to-850degreef-wxmpmsset.htm
(MILL version)
http://www.testequipmentdepot.com/weller/soldering/soldering-iron-sets/wxmpset-wx-series-micro-solder-iron-40w-0052920499.htm
(regular version)
Logged
Mr. Scram
Super Contributor
Country:
Display aficionado
Re: MILL-STD-2000 difference ? Weller WXMP vs WXMP MS
Reply #1 on:
December 20, 2017, 07:42:25 pm »
Just like is the case with calibration reports, pieces of paper that supply traceability and accountability are worth something. I'm not sure that's the case here, I'm curious to learn whether there is any physical difference.
Logged
Fludo
Regular Contributor
Country:
EE
Reply #2 on:
December 21, 2017, 03:59:03 pm »
It could just be a calibration of the iron after manufacturing, or they use a more accurate feedback sensor.
Here's what the spec calls out
MIL-STD 2000 requires that the soldering iron:
Idling tip temp be within +- 5.5C (10F) of set value
The resistance between tip and workstation ground never exceed 5 ohms
The potential difference between tip and workstation ground never exceed 2mV RMS
Iron design should provide zero voltage switching
ESD safe
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
