Author Topic: Weird pushbutton footprint  (Read 1388 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
« on: November 14, 2018, 04:10:46 pm »
http://spec_sheets.e-switch.com/specs/P010337.pdf
Why the heck did they put those spurs on it?  Just make a standard gull-wing pattern with enough soldering area for everthing... ???
On the upside, it's very low profile, and very available right now.  Seems like a reasonable part otherwise.
Seven Transistor Labs, LLC
Offline thm_w
  • Non-expert
Re: Weird pushbutton footprint
« Reply #1 on: November 14, 2018, 09:34:41 pm »
For additional strength maybe, pads could tear? But they are so narrow I'm not sure how much it would help.
If you are using a lot, its cheaper to tape the dome onto the PCB, but for low volume/cost non issue stuff it seems like a good equivalent.
Offline floobydust
« Reply #2 on: November 14, 2018, 10:52:48 pm »
The spurs seem silly, 0.2mm is not going to pull the part centered with surface tension or add more solder paste.
I had bad luck with e-switch samples, I found their plastics can't take heat and they seem to sag after reflow and the spring force plummets. Ends up to be a soft mushy click and I think that brown plastic resin deforms easily. It was a really odd experience; I didn't spec them for production.
