I need a 5x5 inch piece of graphite thats a few MM thick to make a new wear plate.
It does seem to run without the end plate though, I assume its making the motor over heat and maybe effecting the seal. I expect a delusional inventory vader (yeah these guys are not vendors by any means, more like evil) will want 800 for this end plate if i were to buy it.
The endsys atomscope is marketed only towards hot air, and it looks that way, it does not wet at all, its a non magnetic alloy too. I think a iron tip is usually magnetic. The only attachments they sell for it look like needles and thinner needles, realistically just looking at it when I thought It was a desoldering iron I thought 'how the fuck do they transfer the heat through that little hole'.
From how beefy this motor is I don't think it will burn unless it stalls from intermittent use. Right now I can still desolder all the stuff from this PCB manually using only 1 pump per hole, with the manual solder pump some holes require like 35 solder-pump cycles to get a hole that will fit a new component lead.. the problem helius wrote about solder that will just not come out is
very real.
The Sodr-X-tractor was made to be switchable from vacuum to pressure ports to deal with a problem called "blocked blind joints". Basically, you apply vacuum to extract solder, but you can't get air to flow freely because the component on top is sitting too close and blocking air. By switching to blow hot air, the blind joint can be pushed out and the component removed. This tends to make a mess on the bench of solder bits that were in the collection tube...
-totally evil behavior, my main problem with desoldering actually. maybe this is the tool I needed all along. I had one so bad once I spent about 30 minutes trying to desolder one joint before I got the idea to blast it out with dust-off.
Any idea on what kind of graphite is suitable for this? I see there is several different types for sale.
Anyway its cool that it spits fireballs, thats a neat trick. go go gadget plasma cannon
and to be honest my desoldering station that uses the little fan in the tip of the device (something 96D if i recall, I don't even want to look at it) :
1) scares me because its a piece of shit that can easily catch on fire and its proven with russian video evidence
2) has a extremely crappy cord that feels like it is made of metal bars jointed together by springs
3) makes me wanna cry every time I need to use it because of how bulky and ridiculous it is.
4) is super light and annoying and i don't keep it on the work bench
5) probobly has safety ground problems
Having the pump inside of the chassis and a narrow metal soldering pencil that won't get smeared with molten capacitor covers is a totally welcome addition to my arsenal. I will try to stay positive.
By the way any owners of a cheap reflow station, with the blower in the handle, do you ever feel like something went severely wrong with technological trends when you use it? Hmm is dave jones a shill for making me buy this thing? well no.. it works and its cheap.. but something else must be wrong here.. I can't put my finger on it but there is just something wrong with having a blower in the handle. Maybe it was made by people that work on circuit boards like kansas with nothing that has a elevation of more then 5mm (cow on a prairie). Too bad the good circuit boards that you actually want to work on and are useful (cool prototypes, no ones got time for silk screen) usually look like Cydonia, Mars City IV, Down Town red light district circa 4077 AD during the first undead revolt.
I ordered a graphite plate, I am too deep in the game now to give up. I should have at least 3 shots at this.
Also, ordered a pace solder x-tractor.
I think once you take these things apart they have a 'break in' period. What happened is now its running very cool after using for a little, the only heat is towards the end of the motor where the rubbing is on the bare end plate.. someone was using it this way. Anyway I think maybe there was increased friction too because the housing was not well covered in graphite yet since it was deep cleaned with ultrasonic and everything. So if you buy one of these, so long its turning you might wanna give it a 10 minutes of intermittent use. I do believe now that I heard AVE say this about some sort of pump he refurbished but maybe I made it up. When I was first using it, it felt hot to the touch after 15 seconds of use. Now its fine.
Revised opinion on pace : nothing here bothers me except possibly the aftermarket cord that can be lethal and the non welded chassis cover, its just SO janky. But maybe it can take a beating and be put back into place with more simple tools (I know they market towards the military).. so field repair is easier after ?? occurs
