Author Topic: What do people weigh their iron stands down with?  (Read 1369 times)
Offline killingtimeTopic starter
« on: March 30, 2023, 08:04:59 pm »
I've got an Antex bakelite iron stand. Not expensive, but it works, and I like the large sponge. The problem with it being plastic is that it's light and I always end up pushing it round the bench. Sometimes the weight of the cable seems like it could tip the stand over. So what do people weigh their stands down with? I've tried wood but it's not heavy enough. Don't want to glue \ screw it to the desk as it needs to be portable. I could 3d print a box and fill with sand I suppose. Just interested to see what others have done.
Thanks.
Offline srb1954
  • Retired Electronics Design Engineer
Re: What do people weigh their iron stands down with?
« Reply #1 on: March 30, 2023, 09:19:28 pm »
If it has any internal cavities fill them with cement. Otherwise fabricate a bracket to hold a roll of solder on the back - that should provide plenty of weight.
Offline coppice
« Reply #2 on: March 30, 2023, 09:24:23 pm »
If you want a good iron stand you need an iron one, like this https://en.goot.jp/products/detail/st_11 Cheap, simple, in production for decades, and I've never seen one tip over.
Online thm_w
  • Non-expert
« Reply #3 on: March 30, 2023, 09:27:01 pm »
Photo would help.
Gluing large steel washers inside the bottom may be an option.
Needs more brass wool.
Offline jwet
« Reply #4 on: March 31, 2023, 04:25:02 am »
I use a square of hot rolled steel, just a 4x4" x 1/4" scrap.  I sanded it on a belt sander to knock the knife edges and rust off.  I use some magnetic widgets with it- Amazon stuff, one is a iron stand.  I have a thinner steel plate that came with the mag widgets.  The thicker steel really attracts magnets.  I have several irons that I keep on a shelf below my bench (you can see in pic attached somewhat) and have this holder on my bench for the job at hand- a pics attached.
« Reply #5 on: March 31, 2023, 11:10:20 am »
The steel plate looks like a good idea. I'll need to visit a scrap yard.
Thanks for the replies.
