I kind of wonder if the 97 53 14 is cutting some corners, considering the wago one has a selection switch on it for size .... is the mechanism that clever that it manages better quality, with 'automatic transmission', on a wider crimp range, without a selector switch?
I saw them on eBay but I was suspicious... crimp quality will be everything at those current levels IMO.. or wago is just pumping the wallet....
