Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
where I can buy step up transformer DC to DC 24v to 110v
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: where I can buy step up transformer DC to DC 24v to 110v (Read 5579 times)
Unelma
Contributor
Country:
on:
March 19, 2015, 08:39:59 am »
Where I can buy step up transformer DC to DC 24v to 110v.
I need quality one. Kiitos Thank you
Last Edit: March 19, 2015, 06:22:33 pm by Unelma
Logged
Unelma
Contributor
Country:
Re: where I can buy step up transformer DC to DC 24v to 110v
Reply #1 on:
March 19, 2015, 10:00:30 am »
100w to 200w.
Logged
sacherjj
Frequent Contributor
Country:
Reply #2 on:
March 19, 2015, 11:29:04 am »
A transformer that steps down from 110V to 24V will also step up to 110V from 24V if you drive the secondary. If you follow the power rating of the transformer, you are fine.
Logged
wraper
Supporter
Country:
Reply #3 on:
March 19, 2015, 11:34:53 am »
Transformers don't work on DC
Logged
klr5205
Regular Contributor
Country:
Reply #4 on:
March 19, 2015, 11:35:58 am »
You may get better results searching for "Boost Converter".
Logged
sacherjj
Country:
Reply #5 on:
March 19, 2015, 01:57:01 pm »
I totally skipped over that small DC fact. Dolt!
I would be looking at something like the LT3862. It has a high voltage drive for a high voltage source drain MOSFET. That is if you want to build one.
I haven't seen that high of output voltage on a premade DC boost module. How accurate does the DC need to be?
Last Edit: March 19, 2015, 02:57:34 pm by sacherjj
Logged
Seekonk
Super Contributor
Country:
Reply #6 on:
March 19, 2015, 05:04:08 pm »
I buy dead 12V inverters that usually have a bad H bridge. I tear out the H bridge and use 140V DC inverter out to run CFL and electronics like DVD players etc. Easy to bridge the feedback resistor to get 120V DC.
Logged
AlphZeta
Regular Contributor
Country:
Reply #7 on:
March 20, 2015, 05:11:08 pm »
Assuming you need a transformer to build a DC-DC converter, the cheapeast way to go is to salvage a transformer from a 24V UPS (you can pick up one cheaply on eBay).
Logged
Unelma
Contributor
Country:
Reply #8 on:
March 22, 2015, 05:22:30 am »
Thanks for the tips. I found this one just what I was looking for.
www.directindustry.com/prod/absopulse-electronics-ltd/switch-mode-dc-dc-converters-encapsulated-low-profile-railway-applications-34349-1464113.html
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
