Author Topic: Which Additional Tips for Hakko FX-888D Soldering Iron?  (Read 12308 times)
Offline cpsmusicTopic starter
« on: May 05, 2019, 12:10:49 pm »
Hi Folks,
I planning on getting a Hakko FX-888D soldering iron to replace my current iron which I'm not happy with.
The Hakko comes with a Shape-B (No.T18-B) tip. I work in audio production and from time to time make my own gear which ranges from leads to guitar effects through to valve mic preamps, etc.
Just wondering if I should get any additional tips when I order the Hakko?
Cheers,
Chris
Offline Shock
Re: Which Additional Tips for Hakko FX-888D Soldering Iron?
« Reply #1 on: May 05, 2019, 04:15:03 pm »
As a rule of thumb the size of the iron tip should be approximately matched to the size of the pad/joint unless your drag soldering or fixing a bridged joint. I'd go for a couple of chisels, a bevel or hoof for drag soldering, a hook or a blade for rework and a large thermal mass tip for soldering heatsinks potentiometers etc.
Chisel: Good for all through hole and smd but diminishing returns on super fine smd.
Bevel/Hoof: Similar to chisel, not as popular but also can be used to load the tip for drag soldering.
Pointy: Most effective for super fine smd joints. Not the best for ICs unless size matches pin pitch.
Hook: Can be used difficult access joints, remove bridges and to wipe for land prep.
Blade/Knife: Can be used for drag soldering, remove bridges and land prep.
High thermal mass: Used for large heatsinks.
« Last Edit: May 05, 2019, 07:48:42 pm by Shock »
Offline GreyWoolfe
  • NW0LF
« Reply #2 on: May 05, 2019, 05:58:29 pm »
+1, what he said.
Online JackJones
« Reply #3 on: May 05, 2019, 06:14:34 pm »
Back when I used the 888 I had T18-DL32 and T18-DL2 chisel tips. They are a bit sharper than standard chisel tips.
One of them is 3.2mm and the other 2mm, those worked for the vast majority of my uses.
https://www.hakkousa.com/products/soldering-iron-tips/t18-series/t18-dl32.html
https://www.hakkousa.com/products/soldering-iron-tips/t18-series/t18-dl2.html
The following users thanked this post: unixb0y
Offline KL27x
« Reply #4 on: May 05, 2019, 06:49:13 pm »
There are many reasons T18-CSF25 is a highly optimal tip for SMD soldering.
Bevel tips have an oval cut surface, which is the perfect shape for holding a large solder bead and keeping it accessible. Angular tinned surfaces will hold relatively smaller beads before they collapse and they will suck the solder beads away from sharp corners. So you can get these sharp corners/points onto the joint, but the solder doesn't bridge/reach unless you are feeding more of it.
Tinned face only means the sides are chromed, which reduces the surface area of solder that is exposed to air. So the tip doesn't require frequent cleaning and the flux doesn't dry out as fast. Compared to a chisel, for instance, the chisel has that second surface covered with solder that is drying out the flux and making the bead go cold/chunky.
The chrome keeps the bead from creeping around onto the sides of the tip, so you maintain excellent control.
Somewhere between 2.5-3mm is the perfect size of a bevel tip. As you get bigger, the size of the bead gets too large vs surface tension, and gravity stats to collapse the bead if you accidentally get too much solder on there. The 2.5-3mm also holds big enough bead to handle anything, already. I have the 4, too, but it's actually bigger than it needs to be. I have not found any occasion to actually favor it.
Small enough to do most SMD soldering and drag soldering.
When drag soldering, you don't necessarily want to get the entire part to temp at the same time. That can suck a lot of heat into the board unnecessarily. The shape of the bevel tip means you are getting a lot of thermal mass onto a fairly small area of contact, and one which slides easily across pads/pins. The large bevel tip is very efficient in transferring heat; the shorty cSf tip is even better. Because of the large thermal mass, good heat conduction/transfer, and small area of contact to the board that you are heating up, you can use lower temps and still solder/drag-solder without any delay... keeping the solder from drying out and crusting so much longer than with other tip types.
The biggest drawback about using a TFO bevel is that you can't easily feed solderwire onto the top or side of the tip when holding the cut face parallel to the board. This is one reason for chisel tips. But the reality is that for 99% of SMD soldering, you don't need to feed any additional solder when using a 2.5-3mm bevel tip. The tip can hold enough solder for multiple SMD parts. You just apply flux to the pads, place the parts, pick up some solder onto the tip, then wave the magic solder wand around, coloring in the pads. And for through hole stuff, you can turn the cut face vertical and hold it against the leads/pin and feed solder onto the cut face. So a chisel might be slightly better for thru hole, but the bevel is almost as handy for thru hole and much better for SMD, IMO. At first, I would lay out solderwire on a board and pick it up from this board. But what I do ever more is have a solderwire feed attached to my microscope. It hovers a piece of solderwire above the PCB, in my FOV, where I can pick up a bit of solder as I need it.
A cut face bevel is also very good as pulling/sucking out bridges. Really second to none. When the face is wiped clean, it is very effective at sucking bridges. Sometimes, instead of using solderwick directly, I will wipe the tip on the wick then pull the bridge with just the iron. Also, you can lay the solderwick next to the bridge on flat FR-4 and put the tip down so it touches the wick and the bridge.
By controlling how much solder is on the tip, you control how much solder it leaves on given pads. For really tricky things that want to bridge, you will learn easy methods for controlling the amount of solder on the tip. E.g., to install FPC connectors, I solder the structural pads on either side, first, with a healthy bead. Then I wipe the tip and solder the pins. If the solder runs out, touching the tip to the anchor pad will pickup just a tiny bit of solder that is enough finish the pins without making bridges.
Another "weird" thing about using a CF tip is the residue. Burnt flux residue will build up all the way down the sides all the way to the very tip, because there is no solder layer there to allow it flake/wipe off. I just leave it alone and let it build up. I scrape it off only once in a blue moon.
These CF tips are one of the reasons I can't use a weller/ersa/pace. Only Hakko makes them. And they make more of them for the 888 than even the 951. On the 951, you can't get the 1.5mm, 2.5mm short, or 4mm, AFAIK. i don't think the 4 is very great, but the 1.5 (and the 1, which is also available in T12/13) is pretty great for point to point bodge wiring. Other manufacturers might regular bevels. And they might have a "spoon" or "gullwing drag solder" tip, which is a hollowed out bevel tip (worse for thermal transfer and not really that helpful, IMO) but even this won't be a TFO.
« Last Edit: May 05, 2019, 07:30:05 pm by KL27x »
Offline floobydust
« Reply #5 on: May 05, 2019, 07:31:32 pm »
From Louis Rossmann's TS100 review,
"... conical tip so again it is pretty awful, there is really almost nothing worse in life than soldering with a conical tip" (33:40)
"... soldering with a conical tip is just worse than being stabbed in the eye" (34:00)
 :-DD
I just realized, I have to agree - the (straight) conicals I have for the FX-888 have never worked well, just a waste of time.
« Last Edit: May 05, 2019, 07:42:03 pm by floobydust »
Offline KL27x
« Reply #6 on: May 05, 2019, 07:40:43 pm »
Bent conical is way better, but it still has a lot of the same shortcomings. I have them because they look like they solve problems; I have yet to encounter those problems which aren't better solved with a CF. CF not for everyone. It has some unique features/characteristics/quirks. It totally flipped the script for me.
« Last Edit: May 05, 2019, 07:43:00 pm by KL27x »
Offline Mortymore
  • Country: pt
« Reply #7 on: May 05, 2019, 09:00:57 pm »
See if this helps:  Hakko tip shape select
https://www.hakko.com/english/tip_selection/type_bcm_cm.html
The following users thanked this post: SharpDome
