If you are planning on using it on a bench you may be better of buying an old mains powered HP346x 4.5 digit benchtop DMM. It has an LED display so the viewing angle is excelent. Anyway, last year I bought a mains powered Vichy VC8145 because I needed an extra DMM which didn't need changing batteries after using it for several hours. It has an LCD with backlight so its easy to read. The VC8145 is outside your budget but if you can find the money its well worth it.
