Author Topic: Which / favourite Hakko tips? especially for QFN de-bridging??  (Read 2842 times)
Offline ChendyTopic starter
Hi guys,
As per other post, it seems i can/will get Hakko T18 series tips for my Aoyue station.
But which tips to get? Especially for QFN de-bridging: need small enough for access, but large enough correct shape for heat transfer...
gonna buy a selection so recommendations appreciated : )
Re: Which / favourite Hakko tips? especially for QFN de-bridging??
« Reply #1 on: June 17, 2016, 12:41:58 pm »
from googling:
https://www.hakko.com/english/tip_selection/series_900m.html:
"This type differs from Shape BC by the addition of a hollow to its cut face, providing high solder retention capability.
It is used for drag soldering and correction of bridging"
Offline raz221
  • Country: il
« Reply #2 on: June 17, 2016, 01:28:54 pm »
If you ask me, for this particular task, none!
When it comes to surface mount chips (at least for desoldering) you'd be best using a hot air rework station (or just a cheap heat gun) with enough flux around it. You could later on re-solder with solder paste and hot air (actual solder paste, which is gray/black, and not flux, which is sometimes also labelled as such) alternatively, you could apply flux and then do drag-soldering (the 900M-T-2C/900M-T-3C tips would be excellent for that purpose)
Edit: You might find these videos useful btw:
« Last Edit: June 17, 2016, 01:36:54 pm by raz221 »
Offline wraper
  • Country: lv
« Reply #3 on: June 17, 2016, 01:37:56 pm »
For something like this, blade type tips are usually the best.
Offline KL27x
« Reply #4 on: June 21, 2016, 02:17:44 am »
If there's enough exposed pad, almost any tip will do the trick for removing visible external bridges. But I'd say a hoof or a BR would be my preference, were I to have a lot of these things to do, with exposed pad. A knife if you want to waste time trying to dissolve hidden bridges on QFN with barely any exposed pad.
« Last Edit: June 21, 2016, 02:30:27 am by KL27x »
