Author Topic: BGA Reballing Station For FPGA Processors  (Read 854 times)
Offline 2XTopic starter
  • Country: gr
« on: June 22, 2024, 07:55:01 pm »
Hello,
I would like to buy a BGA Reballing Station for desoldering and resoldering FPGA chips like this below on the image. Do you know to suggest me a trusted reballing station or what specs I have to look?
I have never use a reballing station.
Offline PeterG
Re: BGA Reballing Station For FPGA Processors
« Reply #1 on: June 23, 2024, 12:34:58 am »
For reballing i use this jig.
https://www.aliexpress.com/item/32847165892.html
For PGA soldering/desoldering i use this preheater.
https://www.aliexpress.com/item/1005006424862637.html
For larger PCBs or ICs you may need to look at larger tools but these work for most of the work i do.
Testing one two three...
  • Country: gr
« Reply #2 on: June 23, 2024, 11:48:38 am »
Also I found the "IR Preheating Plate T-8280 PUHUI" that have positive feedbacks but I will need an extra arm to hold the heat gun.
