In your pictures there is another inductor which looks very similar.
If it is the same,you may be able to compare them.
Remove both,wire a capacitor in parallel with the good one,feed it with a square wave,& look for the ringing at the top of the waveshape with an Oscilloscope.
Determine the frequency of the ringing--calculate the inductance.
Count the number of rings & their amplitudes
Try the faulty choke:
If the ringing frequency is the same,the inductance is the same.
If there are the same number of rings,& their amplitudes are similar,the "Q" is about the same.
