Author Topic: Wire stripper - nicking wire  (Read 15864 times)
Offline rstor22Topic starter
« on: January 18, 2015, 03:48:15 pm »
In the past I've used the following Klein wire strippers:
http://www.kleintools.com/catalog/klein-kurve-wire-stripperscutters-solid-stranded/klein-kurve-wire-strippercutter-solid-and-stranded-wire
http://www.kleintools.com/catalog/klein-kurve-wire-stripperscutters-solid-stranded/klein-kurve-wire-strippercutter-solid-and-stranded-wire-0
I've noticed that sometimes I would need to use a lower gauge to prevent the wire for getting nicked. For example, when stripping 24 awg solid wire, I found that using the 22 or 20 awg setting works best. The 24 awg setting works sometimes however it is inconsistent and many times causes a nick in the wire. Have others also noticed this or am I doing something wrong? (I've tried to ensure that the wire is not being pulled at an angle)
I recently purchased these Irwin Self Adjusting wire strippers (similar design sold under different names):
http://www.irwin.com/tools/pliers-adjustable-wrenches/self-adjusting-wire-stripper
I found with the self adjusting wire stripper, the wire does not get nicked and I get perfect results consistently.
Offline Christopher
Re: Wire stripper - nicking wire
« Reply #1 on: January 18, 2015, 04:02:50 pm »
I've found this type of stripper to be the best and quickest (for prototype work)
http://uk.rs-online.com/web/p/cable-strippers/0663617/
Offline Balaur
« Reply #2 on: January 18, 2015, 04:25:58 pm »
I must admit that it happens to me as well, even with rather good strippers.
My pet peeve is to see stranded wires with a few cut wires and the remaining going into the crimped connector.  >:(
When I'm not particularly hurried, I go for a two-pass process. The first one is a simple nick using the correct size. Then, I pull the isolation in a second step, using the next, bigger, available size. It seems to work better.
Offline nanofrog
« Reply #3 on: January 18, 2015, 05:22:05 pm »
The plier types you linked (Klein Kurve), are prone to nick or cut strands far more often IME. The latter type you linked from Irwin, and the set linked by Christopher, are referred to as automatics.
FWIW, I use a Pressmaster Embla, which is another automatic. The blade cartridges allow it to do more, which makes it more economical than separate strippers, particularly where Teflon or other hard insulations are concerned. No die nests to figure out either, so even easier to use.  ;)
Offline zapta
« Reply #4 on: January 18, 2015, 05:29:16 pm »
I don't pay attention to guage markings on the stripper,  I just start from a too wide opening and keep narrowing until it strips well, that is, the largest opening that strips that specific wire.
Also, I prefer strippers that have guage adjustments rather than having to choose the right size each time. That's because I typically work with one wire size at a time (solderless breadboard, wirewrap wire, etc).
Am very happy with these two
http://amzn.com/B00004T7WR    // for general wires, cheapo but works remarkably well
http://amzn.com/B005EXNWLM  // for thinner wires
For teflon I am using a Teledyne thermal wire stripper but the first one above should also work well.
« Last Edit: January 18, 2015, 05:31:03 pm by zapta »
Offline bobcat
« Reply #5 on: January 18, 2015, 08:15:32 pm »
Solid and stranded wires have different O.D.
Stranded is slightly larger than solid.
Offline LabSpokane
« Reply #6 on: January 18, 2015, 09:49:15 pm »
Get these:
http://www.amazon.com/gp/aw/d/B000RFSWF8/ref=redir_mdp_mobile?pc_redir=T1
Actually look at the numbers on these they are correct.
Offline David_AVD
« Reply #7 on: January 18, 2015, 11:52:48 pm »
We have a few sets of those at work and the guys love them.
Offline coppice
« Reply #8 on: January 19, 2015, 01:50:53 am »
I haven't used that model, but I have used various self-adjusting strippers. They usually work great on the first day, but go downhill rapidly. I have never seen anyone who works with wire day in and day out use a self-adjusting stripper.
Offline coppice
« Reply #9 on: January 19, 2015, 01:56:17 am »
This is the preferred tool of most people wiring electronics for a living.
Offline radiomog
  • Country: mc
« Reply #10 on: January 19, 2015, 02:12:59 am »
I use a TW-1 Stripall from Kinetics
it's thermal, no nicked wires ;)
http://www.teledyneinterconnect.com/products/stripall/default.asp
My job is so secret, even I don't know what I'm doing!
Offline coppice
« Reply #11 on: January 19, 2015, 03:25:48 am »
At first sight thermal strippers seem to have many advantages, and they used to be available as reasonably priced tools from the major soldering tool makers. They never really caught on, though. I wonder why? I've never used one, so I really don't know the answer.
Offline pickle9000
« Reply #12 on: January 19, 2015, 04:21:06 am »
In Canada electricians (Dave calls these guys sparkies) often use this type. Main reason is the screw/nut adjustment set and forget. When doing a few hundred wires in a row you only have to hit the one hole.
http://www.ebay.ca/itm/1PCS-ADJUSTABLE-WIRE-STRIPPERS-CUTTERS-5-inch-NEW-IN-BOX-Free-Shipping-/251589947975?pt=LH_DefaultDomain_0&hash=item3a93edf247
Offline Electro Fan
« Reply #13 on: January 19, 2015, 04:43:10 am »
http://www.amazon.com/gp/product/B000X4X23U/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
- Very effective and enjoyable to use, highly recommended (this is a set of 2 to cover various size wires)
Offline zapta
« Reply #14 on: January 19, 2015, 04:54:24 am »
Those teledyne thermal strippers have very long work life, All spare parts are available (e.g. spec-all) and teledyne actively support them. I got an old one on ebay for $20, purchased a spare part but it did not fit well (one of the two hands was longer than the other) so sent to Teledyne and they make it right for no charge. That's a great customer service.
Offline zapta
« Reply #15 on: January 19, 2015, 04:59:24 am »
My first ever wire stripper. I used to be good at it, stripping on the right side of the mouth. Self adjustable and no nicking what's so ever. Not doing it anymore though.
Offline Christopher
« Reply #16 on: January 19, 2015, 06:05:49 am »
Using my teeth on PTFE isn't good at all
Offline LabSpokane
« Reply #17 on: January 19, 2015, 06:10:08 am »
For >18ga solid core wire, ok, no problem. For finer gauge and stranded, those things are just wretched. It's difficult to impossible to properly strip a wire without damaging it. You might get lucky, but usually not.
Offline coppice
« Reply #18 on: January 19, 2015, 06:10:57 am »
Teeth do work remarkably well, without nicking the wire at all. It seems like someone should try making a stripper from synthetic teeth.
Offline Balaur
« Reply #19 on: January 19, 2015, 07:15:02 am »
I chipped a tooth like that. And at some point, I think I had a 50% chance of tasting mains. Yay!  :palm:
Offline pickle9000
« Reply #20 on: January 19, 2015, 07:40:08 am »
14ga wire is minimum size here (in a wall), no argument though you are certainly correct.
I normally use my flush cutters. I place my index finger behind the pivot slide the wire in and pull.
I have everything listed here but unless I have 50 in a row my flush cutters end up doing the job. As for the others they all have their place. I like the tw-1 for really thin stuff, the self adjusting one is good on rubber wire and the one that cuts and spreads makes really square cuts in the insulation that looks good on a pcb.
Offline quarks
« Reply #21 on: January 19, 2015, 09:05:22 am »
try Weidmüller Stripax, so far the very best "universal" stripper I used (and proofed very long lasting with daily heavy use).
But even with this great tool, you most likely will need some more other strippers.
Offline Chris Jones
« Reply #22 on: January 19, 2015, 12:44:44 pm »
I do like the Ideal Custom Stripmaster (subtly different from the not-custom one) but it is hideously expensive.
http://www.idealind.com/products/wire_processing/hand_tools/custom_stripmaster.jsp
It is the only thing I have that can strip PTFE wires perfectly without any risk of nicking the wire.
Offline Chris Jones
« Reply #23 on: January 19, 2015, 12:49:32 pm »
The only way to be sure you will never nick the wire is to use thermal strippers. Unfortunately they are not cheap and generate some nasty smoke that needs to be extracted in the same way as solder fumes.
Yes, smoke from PTFE/Teflon is really nasty with hydrofluoric acid and worse (and will also kill birds - common due to non-stick frying pans), and smoke from PVC is said to contain dioxins, hydrochloric acid etc. I would want excellent fume extraction before using a thermal wire stripper on anything other than polyethylene or polypropylene.
Ideal custom stripmaster will not nick wires, but very expensive.
Offline briselec
« Reply #24 on: January 19, 2015, 08:40:06 pm »
Occasionally I'll use a pair of these but most of the time I prefer using worn 7" sidecutters. They easily strip the insulation but because the cutting edges are fairly blunt they don't nick the strands.
