I use variable speed corded 115mm or 125mm grinders (hard pressed to find them now) with various wire wheels and play with the speed control to get the correct 'crap removal' speed
that doesn't impact on the health of the wire wheels, and keep the 'spinning heat n friction' down a tad,
and of course the technique of 'let the tool do the work' and go easy on the force.
So far there's been no unexpected wear and tear, they last ages
Same deal with the flap discs and abrasive cut/grind discs
The speed rating on these consumables is partly so people don't put lower speed discs better suited for drills on high speed grinders, saws etc and wack themselves out
i.e. even though they will persevere, you don't have to use them at full stick.
It's too bad 100mm grinders don't come with speed controls, they are less of a handful to use and the discs cheaper
Not sure if a variac or chopped voltage thingie would fit the bill here, even though they are brushed/universal motors
Hmmm, might see what the local tool repair shop guru can offer as a mod...
