If only they made a D12 (similar to the JBC C245774/158E), or an angled micro hoof like the JBC C245748. Those are pretty much my go-to tips. The knife too (which, along with the C1, are the only proper tips you can get for the TS80/100). You pretty much have to settle for the D24 (which can be too big), the BC2 (which is oval shaped and the skinny end will work), the C1 (which is generally fine for small stuff, but could be smaller), or the B2 (which looks good on paper, but you're right about thermal transfer). Seriously, SainSmart, all you need is 2 more tips, and scrap the TS-I, B2, and ILS!
