Author Topic: JBC SOldering iron connection cable help and insight please.  (Read 3258 times)
Offline PTR_1275Topic starter
« on: September 13, 2015, 06:47:03 am »
Hello everyone,
I recently bought a JBC DDE 2 tool power supply with 2 x 245 hand pieces and bases for the workbench. The problem that I have is that where the DDE unit lives on my bench is a fair distance from where my second hand piece will be.
As a bit of a background which will hopefully answer the "why didn't you use 2 compact stations instead"
In the workshop I have a small bench space that I use for electronics work, I've got the scope, bench meters, power supplies and various other bits and pieces all laid out in front and in a very nice way.
Coming off that bench I have a large area that I keep clean (well try to) for working on big stuff, vehicle fridges, solar panels, standalone inverters and big-ish battery chargers.
As I work on so many varied items of different sizes I cannot use the compact stations with everything bolted to the power supply, it would just get in the way too much.
I have power cables running under the bench from my power supplies to anderson connectors so I can plug things in in that area and it all works well. I used to have a weller wtcpt iron with the transformer mounted under the bench and just the stand and iron on top. This way I can unplug the iron very easily and have the whole bench space free if I need to.
I am wanting to do something similar with the second jbc tool holder / iron in the sense that I run it from the dde control unit, cable under the benches to the tool holder.
Now, the problem is that for me to run the cables nearly under the bench it is about 5 meters. It is about 2 meters in a straight line but that is no where near practical. Mektronics said that jbc only do a 1500mm extension from control unit to tool stand and anything longer than that they experienced issues so jbc refuse to do longer ones.
My thought is that it is purely a voltage drop issue and there is too much lead resistance for the iron to operate effectively. I have multi core cable upto 4.59mm2 of copper (per core) that I was going to splice into the existing cable to extend it but I am not sure if I am missing something. Is my solution too simple or do you think it would work?
If there is anything I have missed, please ask and I will try to answer as best I can.
Cheers
-Chris
Offline RobertHolcombe
Re: JBC SOldering iron connection cable help and insight please.
« Reply #1 on: September 13, 2015, 11:13:33 pm »
I can't offer any wisdom on the topic but your post made me remember this video;
At work at the moment so I can't watch this to see how relevant it is, but may be of some interest. I recall he made his own handpiece or cable w/ connectors so you may be able to do the same without having to buy the A1286
Offline neslekkim
  • Country: no
« Reply #2 on: September 14, 2015, 09:15:17 am »
very good idea, would be nice to do something like that to get more than one tool connected to one station, easier than replug when changing tool)
Offline mve
  • Country: cn
« Reply #3 on: November 29, 2015, 07:18:03 am »
Thanks for this video!
I just got a JBC DI-2D Control Unit that can drive tweezers and T210/T245 and was wondering how to make similar "junction box' for easier  switching without need to unplug-replug the hand peaces each time.
What are these connectors and where did you find them? I was looking long time on a few online part stores but could not find JBC compatible connectors. I can't figure it out the connectors manufacturer - Amphenol have similar once but not quite the same...
N.B. I found it! Here: 1st eevblog.com & 2nd eevblog.com |O
Thank you!
Regards,
« Last Edit: November 29, 2015, 10:52:49 am by mve »
