Author Topic: cheap multimeter  (Read 6193 times)
Offline sony mavicaTopic starter
cheap multimeter
« on: February 02, 2016, 09:41:33 pm »
just wanted to know what is the cheapest one you could buy
http://www.ebay.com/itm/OHM-MULTIMETER-DT830-LCD-DIGITAL-VOLTMETER-AMMETER-Best-Selling-Hotest-/151520414904?hash=item2347520cb8:g:P4EAAOSwofxUk77u
is this the cheapest one with lcd screen?
MORE POWER!
Offline Lightages
  • Canadian po
Re: cheap multimeter
« Reply #1 on: February 02, 2016, 09:59:49 pm »
I have seen that POS as low as $1.97.
Offline ez24
  • L.D.A.
« Reply #2 on: February 02, 2016, 10:15:19 pm »
Offline daybyter
« Reply #3 on: February 02, 2016, 10:25:09 pm »
« Last Edit: February 03, 2016, 12:15:08 am by daybyter »
Offline MrSlack
« Reply #4 on: February 02, 2016, 10:40:36 pm »
Poundland here in the UK sold one for £1 (duh) which works out at the moment about $1.44. I blew the one I bought up in about 5 minutes flat by sticking it on ohms and jamming it in a socket to see what would happen (why I bought it). Loud pop and that was it.
Offline rrinker
« Reply #5 on: February 02, 2016, 11:17:10 pm »
 Can't be any different from the Centech which Harbor Freight gives away for free.
I have a half dozen or so of those, work great for low voltage non precision stuff like model railroads. I've seen the very same thing being hawked by others for as much as $15 - insane!
Offline MrSlack
« Reply #6 on: February 02, 2016, 11:18:11 pm »
I'm in the wrong business for certain if that's the markup!
Offline tooki
« Reply #7 on: February 03, 2016, 12:42:10 am »
Nah, sell cables at retail. Take an ordinary USB cable for instance. Even a name brand cable like Belkin costs only around $2 wholesale in small quantities*. Retailers then sell those for $30. Huge retailers like best buy no doubt get deep discounts on account of buying thousands (maybe millions?) of them at a time.
*Real world example from when I was working at a little computer shop in 1999, when USB was still fairly new. We'd buy just 10 Belkin cables at a time from Ingram Micro and they were still only @$2. We sold them for $12, while CompUSA charged over double for the same item.
Offline crispy_tofu
« Reply #8 on: February 03, 2016, 01:15:40 am »
There's even a UL-listed multimeter of that kind. Why anyone would buy it, I have no idea.   :-DD
Offline ez24
  • L.D.A.
« Reply #9 on: February 03, 2016, 02:12:00 am »
They are cheap and accurate and work and most surprising last (not as long as a $500 Fluck).  Four reasons to buy one.  I am sure there are more reasons.
Offline Brumby
« Reply #10 on: February 03, 2016, 02:21:51 am »
... if it dies, you're out the cost of a cheap lunch - not a mortgage payment.
(Observation not so much on the financial cost - but the stress reaction.)
« Last Edit: February 03, 2016, 02:24:43 am by Brumby »
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #11 on: February 03, 2016, 02:24:50 am »
I have one in my car and one in the shed. I got them free at Harbor Freight on certain sales events. If it's a non-critical and low voltage basic measurement they are OK. I just throw 'em out if they stop working.
Offline MrSlack
« Reply #12 on: February 03, 2016, 06:58:42 am »
To be honest I did from 1994 to 2010 with no brand multimeters. They work pretty well. I had to live on a rather extreme budget for many years. They teach you some tricks to avoid crazy burden voltages and relatively low impedance inputs. Also measured up to 10kv, RF power, approx frequency, capacitance and inductance with some home made adapters.
Offline crispy_tofu
« Reply #13 on: February 03, 2016, 08:15:43 am »
I meant the UL-listed DT830...
I do agree that these multimeters are really handy, but if you wanted safety and reliability, these multimeters wouldn't fit the bill.  :-+
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
« Reply #14 on: February 04, 2016, 11:50:28 am »
AFAIK, all the xx830 DMMs are the same, aren't they?
I also have one and it was my first and only DMM for several years, for 2 reasons: (a) I was on a really tight budget and (b) I didn't know better. Neverthless, this little bastard did help me for quite a while!
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline rrinker
« Reply #15 on: February 04, 2016, 02:06:40 pm »
 Should be, they probably build them all to the reference design.
It all depends on what you need it for. If you need the precision of a 6.5 digit meter, you would never use this junk. For my model railroad stuff, all I care about is if it's in a reasonable range - since the signal is a varying duty cycle square wave, getting an absolute accurate reading isn't easy even with an expensive meter, but all I really care about is that the reading is consistent in all areas so I don't have weird speed variations. If the meter reads 5V, or 20V, I know something is wrong. If it reads somewhere around 12V, it's good - 11.9, 12.4, 13.2, I don't care - as long as everywhere I take a reading it is that same value. For that, these el cheapo/freebies work great. If I knock it on the floor and it breaks, or if a blob of solder falls on the display - no big loss, just pull out a spare and carry on. Even these meters beat my very first one - it was the little blue cheapie KIT analog one from Radio Shack. Might have been about $8 US at the time. It MIGHT have had a 1K input impedance. But very fancy, it had the mirror through the scale so you could correct for parallax.
Offline Rick Law
« Reply #16 on: February 07, 2016, 12:54:00 am »
I've two of them on my table.  Normally one measures V-out of my PSU and the other DT830 measures mV over my 0.1 ohm current sense resistor.
As needed, I may remove it from my PSU and use that as a DMM.
It has better than 1% accuracy with DMM-Check-Plus as the reference.
Great little DMM.
Offline crispy_tofu
« Reply #17 on: February 07, 2016, 05:04:43 am »
My school has two types of these DMMs and they're about the same. There are a few differences though, like input jack sizes and battery access from the back (one is internal, the other has the slide-out one).  :-+
Offline karoru
« Reply #18 on: February 07, 2016, 06:01:34 am »
I've bought this one of ~2$ in Poland (at the local hardware store), mainly because it included 9V battery - I needed one and random brand one costed more than the "meter" with battery included. For the negative price it's pretty awesome (I've tested 2V and 20V DC range) - well within 1% spec. If it had a buzzer I'd keep it for continuity testing, Funny thing, there's a place on PCB to actually put a fuse in it, but they decided to skip it - it probably depends on local market regulations whether you need a fuse on that mA range or not ;)
Offline sarepairman2
« Reply #19 on: February 14, 2016, 05:37:28 pm »
what kind of lunch do you eat? i have like 8-20$ lunches.
gotta have that imported prosciutto and starfruit bro, food is nice!
omg people used to spend like their whole day hunting/farming and now we work all day and try to eat for like 0.0002% of our income. wtf!
« Last Edit: February 14, 2016, 05:41:49 pm by sarepairman2 »
