Author Topic: Yet another microscope thread: Amscope & Eakins  (Read 11717 times)
Offline Electro FanTopic starter
« on: October 04, 2020, 04:15:40 pm »
If both are configured for the same optical specs such as 7X-45X with a 0.5 Barlow, would the image quality be comparable, or is one going to be notably superior?
How do the optics on this:
https://www.aliexpress.com/item/4000052074925.html?gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=0d3ca068-1a16-4e4e-84d9-241a62aeb458&spm=a2g0o.store_home.smartJustForYou_512523718.3
Compare to this:
https://www.amscope.com/7x-45x-trinocular-stereo-zoom-microscope-on-single-arm-boom.html?gclid=EAIaIQobChMI2PGF2Kib7AIVhovICh0qPgeqEAAYASAAEgI1lvD_BwE&gclsrc=aw.ds
If they are comparable in optics, then are we just down to the preference on the stand?  It seems that the Eakins is less expensive and includes a camera.  Plus if the Eakins stand is stable and allows enough room underneath for a PCB it would seem to potentially take offer a better use of bench space.
Offline jfiresto
Re: Yet another microscope thread: Amscope & Eakins
« Reply #1 on: October 04, 2020, 06:48:42 pm »
You know the old joke: What's the difference between marketing and advertising? Well, in this case, you know both advertisers are lying or at least straining the truth to its breaking point. (Eakins more so.) The critical question is will what they actually delivery still satisfy your needs? I would not have high expectations of the Eakins camera: its description is absurdly overblown.
« Last Edit: October 04, 2020, 07:19:34 pm by jfiresto »
-John
« Reply #2 on: October 04, 2020, 07:45:15 pm »
I'm inclined to lean toward what you are saying.  Until yesterday I had never heard of Eakins.  In looking around I found this:
https://www.youtube.com/watch?v=5VzrGNmIApw&feature=youtu.be
The Eakins scope shown in the link is not the Eakins product that has direct vision optics, it's just a camera - but the review is pretty interesting.  Even though the reviewer is a little non-conventional (he seems to multi-task with this daily operations) he is pretty to the point and he gives some good tutorial info on lighting - and his visual demos are pretty compelling.  So, this got me thinking that if their camera is reasonably good and they make what looks like a similarly spec'd optical head, and they packed the two with a stand for a good price, maybe they are onto something at Eakins.  I'm hoping there might be some Eakin's users of the product I linked above or something similar, or better yet some users who have the Eakins scope and a similarly spec'd Amscope.
I'd like a microscope with good optics, a decent work distance (~8 inches or more?), as wide a FOV as practical, and something that is reasonably flexible with respect to zooming  and panning, plus a footprint that is as compact as practical, along with the ability to add a camera later with a simulfocal port.  The head on the SM-4NTP is my reference point so far.
https://www.amscope.com/7x-45x-simul-focal-stereo-lockable-zoom-microscope-on-dual-arm-boom-stand.html
One other feature that I'm trying to confirm is the shape of the barlow end of the scope.  It seems that earlier Amscope models had a bit of a diagonal or curved end; newer versions like the one in the link and others I've seen seem to have more of a cylindrical shape that apparently makes attaching a ring light more secure.
I'm not sure what boom stand makes sense but after watching Louis Rossmann I'm inclined to think that stability is slightly more important than the last degree of high maneuverability.
So, I'm looking for the cake and the ability to eat it too.  :)
Offline HobGoblyn
« Reply #3 on: October 05, 2020, 01:26:20 pm »
I really love my Amscope SM-3NTP.
Mind you, the only other microscope I've used is the https://www.amazon.co.uk/gp/product/B07HDXXKD7/ref=ppx_yo_dt_b_asin_title_o04_s02?ie=UTF8&psc=1.
The Amscope is 1000+ times better.  I find it very comfortable to use.
I've got the single boom arm, I can't comment on whether the dual boom arm would be better as I've never used it, what I will say is the single boom is very sturdy,  it's not going to flex at all.
The only tiny problem I have is that it sometimes gradually slides down the vertical post (not very often, but occasionally).  I've attached a pic where the boom arm attaches to the vertical post.  I have the boom arm nut/lock/screw (green arrow in pic) permanently loose so I can swing my microscope under my monitor when I don't need it etc and I rely solely on the ring underneath (red arrow) to take all the weight.  It's using it like this where slowly over time the ring slides down a little.
When I say it gradually drops, when I first got it it would do this just looking at it, but when I cleaned the vertical bar/post with IPA, it stopped most of this.  I haven't had to raise it for a couple of months now, then again I haven't swung it left or right much either recently (even when I did, I'm talking about once a month if that, not an everyday occurrence).
I suspect it would be the same if I had the dual boom arm, possibly worse as I suspect there's more weight.   While the obvious answer is to also tighten the top one with the green arrow, this tends to happen as I'm moving it left and right, so the top one would have to be loose at this point anyway.
« Last Edit: October 05, 2020, 01:29:30 pm by HobGoblyn »
Offline jfiresto
« Reply #4 on: October 05, 2020, 01:30:52 pm »
The Eakins scope shown in the link is not the Eakins product that has direct vision optics, it's just a camera - but the review is pretty interesting.  Even though the reviewer is a little non-conventional (he seems to multi-task with this daily operations) he is pretty to the point and he gives some good tutorial info on lighting - and his visual demos are pretty compelling.  So, this got me thinking that if their camera is reasonably good and they make what looks like a similarly spec'd optical head, and they packed the two with a stand for a good price, maybe they are onto something at Eakins....
Based on the video and Eakins's aliexpress storefront, I bet Eakins is a company that is happy to sell you something for however much you are willing to pay. I would not count on that quality of video out of the camera that comes with the stereo microscope package you linked to earlier. The video demonstrates a much more camera-compatible monocular "macroscope" and a camera that, alone, costs $40-90 more than the entire package.
Yes, I expect that would be a good setup to aim for. You will also probably want to add (if the microscope does not come with one), an 0.5X auxiliary objective ("barlow") lens to double the working distance and halve the magnification range to 3.5-22.5X, a more useful range for electronic work.
IIRC, Amscope's 0.5X lens has 48x0.75mm male top and female bottom threads. You could screw on below the lens, a 48/52 step up thread adapter and a 52mm UV filter, to hold up a ring light and protect the lens.
Stability and stiffness become more important at higher magnifications or when using a camera.
Some call that cake-ism.
« Last Edit: October 05, 2020, 01:32:41 pm by jfiresto »
-John
Offline jfiresto
« Reply #5 on: October 05, 2020, 01:39:34 pm »
What is the diameter of the vertical post? I am addressing this issue on a stand with a 25mm post, if that is your diameter.
-John
« Reply #6 on: October 05, 2020, 02:51:45 pm »
Thanks.  Your microscope looks snug as a bug on your bench.  That's one of the things I'm trying to solve for - how to get an efficient use of space while preserving the ability to reasonably comfortably use the scope (leave enough space for board inspection/soldering and be able to stay seated or standing while looking into the eye pieces).
I'm pretty sure both the SM-3NTP and SM-4NTP with a 0.5 Barlow will be great for soldering - so it's just down to whether I'd like to give up the extra space for the double boom so as to have some extra flexibility for maneuvering, or save save the bench space.  I'm guessing that if I go for the extra maneuverability I will find that I'll put it in one location and it will just stay there, and if I try to save the space I will find I needed the maneuverability.  :)
Offline HobGoblyn
« Reply #7 on: October 05, 2020, 03:37:28 pm »
Mines 32mm
« Reply #8 on: October 05, 2020, 03:44:20 pm »
HobGoblyn, any chance you could look at the attachment and let me know how these guestimates compare to the actuals?
Thanks, EF
D is from the end of the boom to the center of the lens.
Offline jfiresto
« Reply #9 on: October 05, 2020, 04:42:28 pm »
The only tiny problem I have is that it sometimes gradually slides down the vertical post (not very often, but occasionally)....
Quote from: jfiresto
Mines 32mm
If the slipping is getting tedious, for ca. 17 euros, I can get a split, aluminum collar with a 45mm adjustable hand lever for quick release, adjustment and clamping. I need to ask about the lead time, but could add it to my order and ship it on.
-John
The following users thanked this post: HobGoblyn
Offline S. Petrukhin
  • Country: ru
« Reply #10 on: October 05, 2020, 09:45:13 pm »
I use a microscope like this: https://aliexpress.ru/item/32827387014.html
And here is a tripod: https://aliexpress.ru/item/4000328478089.html
The microscope is very good, I am satisfied. Very light. The tripod was a little awkward. I removed the heavy base and screwed the axle to the table. The base tipped over at maximum take-out. The horizontal movement of the guides is poor (no bearings), but it is a very stable tripod.
« Last Edit: October 05, 2020, 09:47:31 pm by S. Petrukhin »
And sorry for my English.
  • Country: ru
« Reply #11 on: October 05, 2020, 09:54:03 pm »
I highly recommend using these clamping handles: https://aliexpress.ru/item/32863371978.html in the twisted state, you can pull and turn the shank so that it does not interfere.
Offline HobGoblyn
« Reply #12 on: October 05, 2020, 10:23:31 pm »
Thanks, EF
Sure, am in bed now, will do it tomorrow
Offline jfiresto
« Reply #13 on: October 06, 2020, 06:06:39 am »
Those adjustable handles are very nice and I was going to suggest more of them if you guys wanted to pimp your 'scopes. You would probably want ones with soft-tipped screws if they will press against the shafts, but I may be getting ahead of myself and will keep quiet.
-John
Offline HobGoblyn
« Reply #14 on: October 06, 2020, 11:44:34 am »
Thanks, EF
A: 25”
B: 9 1/2”
C: 16”
D: 21 1/2”
E can’t do as cable ties all around C
« Reply #15 on: October 06, 2020, 02:15:24 pm »
Thanks, EF
A: 25”
B: 9 1/2”
C: 16”
D: 21 1/2”
HobGoblyn, Thanks for making the measurements.  Looks like there is about 1.5” somewhere I hadn’t accounted for.  Might have another question or two for you later.... Hope you will keep us posted on your findings as you work with the scope and stand.
« Reply #16 on: October 06, 2020, 11:24:06 pm »
HobGoblyn and other Amscope users, another question, please/thanks:
In looking at Amscope's various heads there is a SM-3NTP (and a similar/same? head on the SM-4NTP):
https://www.amscope.com/7x-45x-simul-focal-stereo-lockable-zoom-microscope-on-single-arm-boom-stand.html
In the photos it looks like the lens (facing down toward the object being viewed) is symmetrically cylindrical.
They have other similar products such as the SM-3B (and others in the 4 series):
https://www.amscope.com/7x-45x-stereo-zoom-microscope-with-single-arm-boom-stand.html
In the photos it looks like the lens (facing down toward the object being viewed) is not symmetrically cylindrical, rather it it is tapered.
It seems like the cylindrical housing would hold the ring light better than the tapered version - not sure if either the cylindrical or the tapered have any different optical performance.
Which version do you have?  Anyone know why there are/were two versions and which is the most current?
If you look closely you will see that the head housing is somewhat different with the controls either forward or rear facing.
Thanks
Edit:  maybe it doesn't matter for securing the ring light if you are using the cylindrically shaped 0.5 Barlow?  Still curious as to why they show two different shaped lens housings.... Thx
« Last Edit: October 06, 2020, 11:54:23 pm by Electro Fan »
Offline jfiresto
« Reply #17 on: October 07, 2020, 07:06:41 am »
...  Still curious as to why they show two different shaped [objective] lens housings....
Amscope's supplier(s) probably copied different microscope designs: the sloped housing coming from Nikon and the stepped design from Meiji Techno. (If I were buying a new microscope as a lifelong tool, I would probably get a Meiji.)
-John
« Reply #18 on: October 07, 2020, 06:22:46 pm »
Thanks, I'll take a look at Meiji but just in case I'm still trying to understand which is the current version of Amscope and why there was a change.
For anyone looking through the microscope threads and finding this post, here are a couple posts that I just found and found useful:
https://youtu.be/sZqCsk0kGm8
After watching this and other "reviews" I think Eakins is probably using the same basic microscope as Amscope - the general consensus (which is not officially confirmed as best I know but is likely correct) is that the Amscope and Eakins heads come from the same factory.
The second video gives a good demo showing how various lens configs result in various working distances including some useful measurements of the working distances.
There are also some good discussions in the videos and the comments related to cameras and how the extent to which the cameras can be installed so as to give a similar view as what is seen through eye pieces.
For completeness, another video that tripped my trigger was this one - particularly with respect to how various lights effect what you see through the microscope, and what the camera sees.  This fellow isn't quite as polished as the first but he's a good multi-tasker and the content on lighting is useful, I think.  YMMV
One more as a bonus:
« Last Edit: October 07, 2020, 07:08:43 pm by Electro Fan »
Offline HobGoblyn
« Reply #19 on: October 08, 2020, 10:42:24 am »
Mines cylindrical, looks the same as your cylindrical photo and was bought from Amscope April this year.
« Last Edit: October 08, 2020, 10:47:46 am by HobGoblyn »
« Reply #20 on: October 23, 2020, 12:26:44 am »
Thanks, EF
A: 25”
B: 9 1/2”
C: 16”
D: 21 1/2”
Hi HobGoblyn (or other Amscope SM scope users),
Any chance you could measure the vertical distance from the plane of the objective lens to a plane even with the top of the oculars?  I'm guessing it's on the order of 10 inches / 25 cm but that's just a guess.  Thanks
« Last Edit: October 23, 2020, 12:29:33 am by Electro Fan »
