Author Topic: Yihua 882D+ - Problems  (Read 5814 times)
Offline cs.dkTopic starter
« on: November 06, 2013, 07:19:52 pm »
After fixing my scope, with great help from this forum, my solderingstation broke down same day |O Picture of the thing here: http://www.aliexpress.com/store/product/YIHUA-882D-Brushless-fan-rework-station/401349_488178717.html
The hot-air part works fine - But when turning on the regular iron, the display just says "S-E", and the iron does not heat up.
I can't find a manual for this damn chinese thing. Btw. usually it works fine, very fast heat-up, etc. I was actually happy with it.
Any clues?
Offline Rory
Re: Yihua 882D+ - Problems
« Reply #1 on: November 06, 2013, 07:46:26 pm »
Yihua claims 1 year warranty. Here's link to product support page...
http://yihua-gz.com/support.asp?id=12
« Reply #2 on: November 06, 2013, 08:07:23 pm »
I think it's more then a year old.. But i'll try to send them an email. Maybe thay will answer it, but i doubt.
Offline netdudeuk
« Reply #3 on: November 06, 2013, 11:25:01 pm »
Maybe a bit obvious but have you checked the continuity of the element ?
Offline sync
« Reply #4 on: November 07, 2013, 02:39:34 am »
On my XY-tronic station S-E stands for Sensor-Error. Check the temperature sensor in the handle.
« Reply #5 on: November 07, 2013, 04:14:22 am »
Not yet, but will do when i come home from work.
That makes sense. I'll check it out later.
« Reply #6 on: November 10, 2013, 09:32:01 am »
Looks like spareparts are needed. |O
« Reply #7 on: November 10, 2013, 10:01:15 am »
Drop test failed there, or you need to use some Copaslip on the new element to prevent it seizing on the element. It will smoke for a few minutes on the first power up but will be fine.
