Probably running at 15kHz or so, those look like old LOPT cores, and they work well at that frequency. Might be higher, up to 30kHz, but those multipliers use high voltage diodes and they generally are not going to be terribly fast switches, they generally have a max frequency limit of around 25kHz. The capacitors inside are likely to be hundreds of picofarads at around 20kV each, thus the big potted assembly, to keep the oil from damaging them.
there must be a driver with a push pull output in the controller driving them, likely running off a power rail of around 150VDC or so, at a current of around 5A peak.
