Some 19 months ago, I bought a ZD-8915. In a local store even, but it is still China stuff.
And at first, I was very happy with it. Still am, despite what I am about to write, would buy again.
But I started to get small annoyances. Being:
- Very loud FAN. I thought it was broken.
Like many others, I replaced the fan nearly instantly, but that did not work. Below I explain why.
- Power switch on the back
Has been moved to the front a while back.
- Extremely slow heatup time. 10 minutes to 400C (which is really only 350C)
Main mod for this post.
- Temp is off by about 50C (edit: now also fixed)
- Bad sleep mode. Handling does not keep it awake, I have to hit something with the gun
- I may eventually also add a delayed vacuum valve, as I have seen others also do.
So, it turns out the noisy fan and the slow heat-up time are related. The problem is, it has a 24V heating element, a 12V air pump, 12V Fan; But a 18V power supply.
So putting a 24V 90W heating element on 18V
yields only 50W. And indeed, checking consumption that is what it takes.
That is the slow heating explained.
[attach=1]
Furthermore, the 18V is dropped with 2 ceramic 1R5W resistors to 12V for the airpump. Very wasteful.
BUT, the 12V cooler fan is on the same resistively dropped 12V rail as the Airpump.
Ergo, it is nearly always running on 18V !!Only when you run the pump does it drop to 12V, but I never noticed the fan sounded better when the pump was running. You know, with the added pump noise.
And when the pump does not run, then voltage barely drops, so the full 18V over the 12V fan.
Yeah, that will make it sound as if it is about to explode alright....
And finally, not very critical, but also a bit silly:
The control board is running from a 78L05, is again from the 18V, but again resistively dropped to 15V.
The resistivity dropper is inside the PSU even, so it needs two extra leads out of the PSU. Not sure why. Maybe the 78L05 gets to hot from 18V, but not from 15V?
The Mod:I modded the PSU from 18V to 24V by tweaking the resistor network around the TL431AA voltage reference.
Adding a 68K resistor parallel to the R8 resistor (24K Ohm) yielded 23.5V output. Which is good enough, especially as the capacitors are only rated for 25V
[attach=2][attach=3]
Next I added a cheap DC/DC board to convert the 24V to 12V, and will now feed all 3: airpump, control board and fan, without any resistive dropping.
I did test if the board could handle a continues 2.5Amp for the Airpump. Not that the Airpump runs continuously, but to be sure...
[attach=4][attach=5]
From the PSU, I removed the thin 15V red/black leads for the control board (the resistive dropper for that was inside the PSU), as well as the 18V thin black/white leads for the airpump. And instead added proper (thicker) Red/Gray wires. The reason for the odd Red/Gray color combo is that the original colors were also odd.
For example: two of the black wires of the PSU were +18V, and one black wire was GND.... Go figure the logic of that....
So anyway, as I did not want/need to change the Black/White wires to the Iron, I kept Black as +V, and chose different colors for permanent 12V and permanent 0V
original new meaning
Black (thick) Black +18V (now +24V) for Iron (unchanged)
White (thick) White PWM switched ground for Iron (unchanged)
Black (thin) Red +18V (now +12V) for Airpump/Fan (now also Control board)
White (thin) Gray permanent ground
Red (thin) -- +15V for Control board (removed)
Black (thin) -- ground for Control board (removed)
Orange (thin) Orange opto-coupler to Switched Iron ground
Green (thin) Green opto-coupler to Switched Iron ground
The power distribution board also was slightly changed. Basically, I removed the two large resistors, and re-used their pads to create a +12V and 0V point for the control board wire. Not too hard, see the images.
[attach=6][attach=7]
Now the device heats up much faster, draws the listed 90W while doing so. And the Fan sounds more reasonable.
I may still changed the fan for an ultra-quiet one.
Mods I may make in the future
- Replace Fan by more quiet one, and add internal shroud for more logical airflow
(but the airpump is noisy anyway, so maybe not)
- Tune the pots on the control board to see if I can make the temp readout better
(did not touch them yet) done
- Add small vacuum delay valve in the handle, so the suction comes in with more of an initial burst.
Something like this:
https://youtu.be/j8LMdIZuDyw but nicer looking)
- Put a relay for the AirPump, rather then running 3A over the tiny conductors and microswitch of the gun.
- Link the sleep/shake input to the trigger switch
Or not. After all, it is working, and I do not need to wait 10 minutes anymore every time I want to use it, so I may loose interest.
Anyway, let me know if you have suggestions, of if you thought this useful.
Have a nice day.
PS: if someone knows why my inline images are not working, please reply or even dm me.
