I'm almost done hacking an industrial energy meter which I will install as a secondary meter, allowing me to continuously monitor energy consumption in my house across 3 phases. However, this is not quite fine-grained enough for my liking, ideally I'd like to drill down to specific devices/outlets.
Now I can't very well construct my own meters and connect to mains; mostly due to safety and cost issues. However, I came across
this product, which looks nice and cheap. The downside is that it appears only a maximum of 5 meters can be used (though I hope this is strictly a limitation of the receiver) and also I doubt if there are rs-232/USB interfaces of the receiver I can utilize.
How hard do you guys think it would be to construct hardware to listen in on the popular 868MHz band for me to start reverse engineering the data protocol itself? The 868MHz is just a carrier, I assume there are countless ways to modulate the actual digital signals on top of this, but are there cheap de-facto standards I may cut my teeth on first? I realize encryption might also be an issue, but for now I am mostly interested in the hardware aspect and whether there are easy and popular 868MHz kits/builds for starting hacking.
Naturally, I'd also like to hear if anyone are aware of alternatives to the product I mentioned.
