Author Topic: 2.4 Ghz DIY dipole Antenna  (Read 6391 times)
Offline soligenTopic starter
« on: October 12, 2017, 03:01:45 pm »
I have been looking for instructions for making a sleeved dipole antenna for 2.4 Ghz for use on my DIY RC receivers.  I haven't found anything that clearly specifies the all the specific lengths of each part of the antenna, I imagine because there are so many variables.
Although I don't really have the kit needed to evaluate an antenna design, I have been experimenting and this is what I came up with.  I am looking for feedback if I should adjust any lengths, and if someone with the equipment to properly test this antenna would like to help be out by testing it, that would be wonderful.
Desired center frequency 2.425 Ghz
Coax: RG-178 (velocity factor .69)
Sleeve length: 26mm
Element length : 28mm
Coax feed length: 170mm (2 wavelenghts x velocity factor)
The sleeve was made by folding the braid back and flooding it with solder.  The primary element ends up with 2 layers of heat shrink (over the dielectric) and the sleeve ends up with one layer.  Pic attached showing 3 different stages of the build.
My tuning was done with my Taranis RC transmitter which has a RAS indicator which is supposed to be SWR.  I had the same good reading at 27, 28, and 29mm, so I took the middle length.
For reference, here is my RC receiver project: https://github.com/soligen2010/RC_RX_CABELL_V3_FHSS.  I have made a number of receivers that work well, but when I try to send telemetry from the RX back to the TX, it is way less reliable that the signal from TX to RX.  I am thinking the best antenna I can make would help this.
Thanks
« Last Edit: October 12, 2017, 03:04:23 pm by soligen »
The following users thanked this post: laneboysrc
Offline NiHaoMike
    • Facebook Page
Re: 2.4 Ghz DIY dipole Antenna
« Reply #1 on: October 12, 2017, 05:04:55 pm »
Make a biquad for the ground station. It is both compact (unlike a dish or cantenna) and high gain.
« Reply #2 on: October 12, 2017, 07:48:37 pm »
Thanks for the suggestion.  I have tried a 5 DBi antenna on the ground station, but not a biquad - I am concerned it will be too directional.  I'll look into this once I am happy with the RX antenna.
For this thread, I really want to focus on the RX antenna (in the plane) which needs to be omni-directional and reasonably small
Offline Gribo
« Reply #3 on: October 12, 2017, 09:26:11 pm »
Your dipole is a bit on the short side. Wavelength in air @2.4GHz is ~12.5cm. The exposed parts of the coax should be ~6cm, not 3.
I am available for freelance work.
Offline TheSteve
  • Living the Dream
« Reply #4 on: October 14, 2017, 05:26:16 am »
He built a dipole which should have 1/4 wavelength radiating elements so his measurements are fine.
VE7FM
« Reply #5 on: October 16, 2017, 02:04:06 pm »
Correct, and since my elements are not in free space, my understanding is that this should shorten things as well.  They are different lengths, but the bottom is fatter then the top, and I also read somewhere that fatter elements should be shorter too (Can anyone confirm?).  So, intuitively these seem reasonable to rookie me,  but I don't fully understand antenna design, and I don't own the gear to properly evaluate it, so any info from people with experience on 2.4 antennas would be appreciated.
I had also tried making the sleeve from 1/8 inch (just over 3mm) O.D. brass tubing.  I had the same results testing on my Taranis TX.  I went with the folded back braid just because it required less materials to make the antenna.
BTW I has started with 31mm both top and bottom, but that antenna performed very poorly.
Offline cdev
« Reply #6 on: November 06, 2017, 12:46:38 am »
Why not make a turnstile or quadrifilar helix antenna? (circular polarized) antenna. Or maybe a clover leaf style antenna. They are circular polarized so are particularly good at rejecting fading. Just make sure both antennas are identically polarized.(stick with either RHCP or LHCP)
« Reply #7 on: November 07, 2017, 02:57:57 pm »
Thanks for the suggestion.  On an RC plane or quadcopter I am a bit concerned that these would be too fragile.  Cloverleafs are used at 5.8 GHz in RC for video, but they are a lot smaller than 2.4.
How do you think mixing these antenna types would work out.  A simple dipole on the plane (actually 2 dipoles on the plane as it has diversity) and one of these others on the transmitter.
Offline cdev
« Reply #8 on: November 08, 2017, 12:03:48 am »
You should ask people who fly RC aircraft a lot.
I have never flown one. The big advantages of circular polarization is freedom from fading and rejection of noise. Its likely better than diversity in that respect if there is line of sight between the two stations.
The explanation is fairly technical but Wikipedia explains it fairly well.
https://en.wikipedia.org/wiki/Circular_polarization#Antennas
The best way to use a circular polarization antenna is to communicate with a receiver with another circular polarization antenna of the same sense.  In that situation there are a number of advantages over linear polarization which apply especially to communication between a ground station and an aircraft or space vehicle.
You could use two circular polarization antennas on receive in diversity, sure. Would that be more reliable? Its hard to say. Diversity usually offers an improvement in signal reliability, but in this case I am not sure if it would add anything.
Having the opposite polarization would not buy you anything unless you were trying to receive a circular polarization signal that had reflected off of a flat conductive surface an even number of times (like once)
I would not expect adding another, linear polarized antenna to be more than marginally helpful if the transmitting antenna was circular polarized.
So what I am getting at is diversity and circular polarization are two ways of attempting to solve functionally similar but not identical problems that make the "sum" of using the two together likely to not be as large as one might think. Or so I suspect.
Ask the RC community.
« Last Edit: November 08, 2017, 10:53:04 pm by cdev »
Offline NiHaoMike
    • Facebook Page
« Reply #9 on: November 08, 2017, 05:03:46 am »
One reason to use two antennas of opposite polarization is MIMO, which is not your case.
