Author Topic: 2-4W VHF Linear PA suggestions  (Read 1119 times)
Offline vu2tveTopic starter
  • Country: in
« on: January 21, 2022, 03:49:46 pm »
I need to build a driver stage that will sit between a LimeSDR and a MRF101AN based final output stage.
I'm shooting for about 16-18 dB of gain, and a final output power of 33-35dBm.
Any suggestions where I can look for to begin design? I'm not averse to building PCB's if there are good reference designs available. I'm looking specifically at the FM Band of 88-108MHz
P.S. I know that the drive needed by the MRF101AN is just 1W. However, I would like to have some legroom so having a max output power of 2-3W is desirable. I can tweak the signal power from the LimeSDR to get the right output power.
Thanks!
Online David Hess
  • DavidH
Re: 2-4W VHF Linear PA suggestions
« Reply #1 on: January 21, 2022, 11:45:00 pm »
Other than cost, why not cascade two MRF101AN stages?
The following users thanked this post: vu2tve
Offline M0HZH
    • QRPblog
« Reply #2 on: January 22, 2022, 12:26:00 am »
LimeSDR will require some output filtering before amplifying.
RD06HVF1 is commonly used for HF/VHF and will fit the bill on gain and output power; it runs at a lower voltage (13.5V typically) than the MRF101 stage and there is an official application note for 175MHz that could be adapted:
https://www.mitsubishielectric-mesh.com/products/pdf/rd06hvf1.pdf
There are 88-108MHz designs out there that use it, it's worth looking around.
  • Country: in
« Reply #3 on: January 22, 2022, 06:32:20 am »
I was just thinking that myself!! Thanks for nudging me further. I have an MRF101AN on hand and am going to build another PCB for it.
Also, I contact NXP and they recommended these two active part numbers - MW6S004N and AFIC901N.
Thanks!
  • Country: in
« Reply #4 on: January 22, 2022, 06:34:40 am »
Yeah. I can see some ebay sellers selling this part.
Long ago, I had purchased a "15 Watt FM amplifier" from aliexpress that used RD15HVF1, and after much headache, it turned out that the transistor was a dud :(
So I'm thinking I'll order a couple of RD06HVF to experiment with, but possible go with active part numbers sold through mouser/digikey etc, so that I don't run the risk of getting a dud.
  • Country: in
« Reply #5 on: January 22, 2022, 06:38:24 am »
Also, I see this part number being mentioned a bit too - rqa0009 (does not seem to be an active part, except being found on ebay)
wonder if there is some experience in the community here with this (https://aliot.com.ua/pdf/rqa0009.pdf)
