I need to build a driver stage that will sit between a LimeSDR and a MRF101AN based final output stage.
I'm shooting for about 16-18 dB of gain, and a final output power of 33-35dBm.
Any suggestions where I can look for to begin design? I'm not averse to building PCB's if there are good reference designs available. I'm looking specifically at the FM Band of 88-108MHz
P.S. I know that the drive needed by the MRF101AN is just 1W. However, I would like to have some legroom so having a max output power of 2-3W is desirable. I can tweak the signal power from the LimeSDR to get the right output power.
Thanks!
