Author Topic: Need info about this FM transmitter (1 of 2)  (Read 1658 times)
Offline MerlysysTopic starter
« on: May 03, 2016, 06:24:16 pm »
I want an FM transmitter to do some experiments with (using load)
http://www.ebay.ca/itm/222099498416
Specs are given as
  - Output power: 3 DBM - 15 DBM
  - Working frequency: 85 MHZ--115 MHZ
Is this really an FM transmitter? If so what would the max power output be? Is it possible to convert dbm to watts?
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Need info about this FM transmitter (1 of 2)
« Reply #1 on: May 03, 2016, 06:34:37 pm »
Well, that's what they claim. Buy one and see.  :-//
dBm is power relative to 1.0 mW. 0.0 dBm is 1.0 mW of power, so (+) 3 dBm would be twice that or 2.0 mW. (+) 15.0 dBm is 31.6 mW output power.
Offline Ammar
« Reply #2 on: May 19, 2016, 12:40:33 am »
It very much could be. I assume those SOT-23 packages are discrete transistors. I don't know why they have bothered when there are many integrated solutions. Looks like a cheapy. Expect the frequency to drift if you do get it.
Offline mos6502
  • Country: aq
« Reply #3 on: May 19, 2016, 08:01:06 am »
It's just your standard 3 transistor FM bug. Dozens of circuits out there. Transistors used:
J6 - probably MMS9014
J8 - MMS9018
for(;;);
