Author Topic: 200Mhz in a 14 pin DIP???  (Read 3615 times)
Offline oilburnerTopic starter
« on: May 18, 2016, 05:39:04 pm »
I thought my "google-ing" was strong, but I can't find out what chip this is, any ideas?
We know we can't make this for $25 shipped, so I don't why the sandpaper was used...
It uses 12V for power and the voltage to tune, if that helps.
Thanks!
g
http://www.ebay.com/itm/131700683861?rmvSB=true
Offline ataradov
    • Personal site
Re: 200Mhz in a 14 pin DIP???
« Reply #1 on: May 18, 2016, 05:59:08 pm »
MC1648
Alex
Offline chris_leyson
  • Country: wales
« Reply #2 on: May 18, 2016, 08:27:03 pm »
That's a blast from the past, last time I used an MC1648 it was 35 years ago, they've got to be new old stock unless ON Semi still make them.
Offline mos6502
  • Country: aq
« Reply #3 on: May 18, 2016, 08:39:25 pm »
Oooh, all of 200MHz. How about 2.4 GHz?
for(;;);
Offline edavid
« Reply #4 on: May 18, 2016, 09:31:07 pm »
MC1648
You would think that if they were using the MC1648, they would have made the board run on 5V instead of 12V.
« Reply #5 on: May 18, 2016, 09:32:15 pm »
Wow, you guys are quick, thanks!  Looking at data sheets, and learning : )
g
Offline ataradov
    • Personal site
« Reply #6 on: May 18, 2016, 09:33:51 pm »
It might be designed to work from an unstable power supply or just for 12V system. You can clearly see a voltage regulator there.
Pinout matches MC1648, so I'm pretty sure it is the IC used here.
Alex
